2013 Escape 1.6L
Was throwing P0135 but I'm a bad car owner and let it go for too long. Most recent OBD check threw P2626 code (Upstream B1,S1), so I replaced the part. Used NGK part. Now it won't start or even make sounds for ignition.
For context of my procedure, I removed the battery, the air filter housing and unplugged the MAF. The Batter Junction Box connector (I think- C1035C is the designation in a diagram) was in the way to I unplugged that as well. After replacing the part I put everything back.
I tried to run the relearning idle/fuel trim but the error code "Engine Fault Service Now" won't let the car proceed to ignition. I can turn the key all the way forward but nothing happens.
I also tried resetting the battery with a method from YT: Turn on brights X5, then press breaks X3 and wait for battery light to blink.
- There is no illuminated battery light so nothing to blink.
Could be bogus but I'm not a technician.
I have the Hynes manual and am competent enough to do minimal maintenance.
Any suggestions or guidance would be great.
