Hello everyone!
I am driving a Mystery Machine, This post is specific to one of the many issues I am having with this car.
I had my mechanic take my car to one of his colleagues to install a new transmission. Once I got the car back: the speedometer and odometer didn't work, the Hill Start Assist alert was on, the ABS and traction light was on. NONE of these issues were present before I gave the car to my mechanic. I did some research and found that it might be the wheel speed sensor (VSS), but it was all connected to the rear axle when I gave it to him prior. I suspect that it is connected since I drove it out of his garage, but I don't think it was reset (if that's even a thing that's required). I am in need of guidance to how to fix this issue ASAP. Any advice or solutions to such issues?
Hello everyone!
Take your car back to your mechanic, Who accepted your money to fix the problem but did not.
  • Like
Reactions: Charles
Administrator
I agree with Mountain Escape that you need to take your Escape back to the mechanic. I would tell him all the issues that are occurring now that weren't prior to him/her "fixing" it.
All the items mentioned are related to the wiring associated with R&R of a transmission. If you are lucky, it just means that the tech needs to connect the speed sensor, the tone ring(s) connector. If not, they may have been damaged when the work was done, and either the sensor or connectors will need repair.
While checking things, be sure that your reverse/backup lights work and if you have a in-dash display that shows your rearward path, that it is working too.
