Hi Guys,
I've recently picked up a 2004 Mazda Tribute - all is good except the steering wheel doesn't look straight when I'm driving straight.
I've had the tracking checked and that is all looking good - the garage advised me to align up the steering wheel itself. The tribute runs straight and well, it's just the steering it out.
So, this morning, I stripped down the steering wheel etc, took the front of it off - then discovered there looks like some kind of locking screw that is accessable under the steering wheel (just inside the small plastic cut out on the wheel itself). It's a 7mm bolt that seems to tighten the bolt that locks the steering wheel down.
However, when I loosen it, I still can't move the steering wheel at all.
Is there something else I need to do to rotate it?
Do I have to completely remove the wheel and rotate it 1 notch on a spline?
Is there some way to lock the steering column, so I can put a bit more force on the wheel?
Can someone point me in the right direction? - It really looks like this bolt is here for this exact reason..
