1 - 3 of 3 Posts
I recently purchased a 2010 Ford Escape Hybrid Limited with Navigation. I was wondering if there were any hidden places with A/V or at least where I might be able to wire in a A/V jack?
EDIT: Looking for output jacks, not input (although input would be fun too).
Any ideas?
My suggestion would be to get a wiring diagram for your vehicle via ALLDATA or some other source. The wiring diagram will give you an idea of how, what and where things inputs and outputs are located. You can also try your onwer's manual that list all inputs and outputs.
Good luck.
I have the 09 with Nav. There are no RCA or video outputs, but here is the wiring chart. I verified these with my install so the colors are correct.
The speaker outs go to the speakers (not the amp), the amp is only for the subwoofer, and it is supplied a 6 volt remote turn-on (so it is no good for use with aftermarket amps).
Also, this is for non-hybrid, so I don't know if there is a difference between the 2 nav systems but I would think there is not.
C240A
AUDIO CONTROL MODULE (ACM)
Pin Circuit Gauge Circuit Function Qualifier
1 SBP39 (WH-RD) 16 FUSE - 39 OR CIRCUIT BREAKER
2 * * Not Used
3 DME07 (-) 20 CTRL MOD. - AUDIO # FRONT
4 * * Not Used
5 * * Not Used
6 * * Not Used
7 CME27 (YE-VT) 18 CTRL MOD. - AUDIO # ENABLE / CLIPPING
8 VME07 (WH) 18 CTRL MOD. - AUDIO # SPEAKER LEFT FRONT DOOR (WOOFER)
8 VME07 (WH) 22 CTRL MOD. - AUDIO # SPEAKER LEFT FRONT DOOR (WOOFER) AMPLIFIER
9 VME09 (WH-GN) 18 CTRL MOD. - AUDIO # SPEAKER LEFT REAR
9 VME09 (WH-GN) 22 CTRL MOD. - AUDIO # SPEAKER LEFT REAR AMPLIFIER
10 VME12 (BN-WH) 18 CTRL MOD. - AUDIO # SPEAKER RIGHT REAR
10 VME12 (BN-WH) 22 CTRL MOD. - AUDIO # SPEAKER RIGHT REAR AMPLIFIER
11 VME10 (WH-VT) 18 CTRL MOD. - AUDIO # SPEAKER RIGHT FRONT DOOR (WOOFER)
11 VME10 (WH-VT) 22 CTRL MOD. - AUDIO # SPEAKER RIGHT FRONT DOOR (WOOFER) AMPLIFIER
12 RME10 (WH-OG) 18 CTRL MOD. - AUDIO # SPEAKER RIGHT FRONT DOOR (WOOFER)
12 RME10 (WH-OG) 22 CTRL MOD. - AUDIO # SPEAKER RIGHT FRONT DOOR (WOOFER) AMPLIFIER
13 GD115 (BK-GY) 16 GROUND - CROSS CAR BEAM # 2ND STUD
13 GD115 (BK-GY) 18 GROUND - CROSS CAR BEAM # 2ND STUD AMPLIFIER
14 * * Not Used
15 CBP28 (GY-VT) 20 FUSE - 28 OR CIRCUIT BREAKER
16 RME24 (BU-WH) 22 CTRL MOD. - AUDIO # SWITCH REDUNDANT AUDIO
16 RME54 (WH-VT) 22 CTRL MOD. - AUDIO # SWITCH REDUNDANT AUDIO CDX6
17 VME54 (BU-OG) 22 SWITCH - REDUNDANT AUDIO
18 VME14 (GY-YE) 22 SWITCH - REDUNDANT AUDIO
19 RME24 (BU-WH) 22 CTRL MOD. - AUDIO # SWITCH REDUNDANT AUDIO
20 * * Not Used
21 RME07 (WH-BN) 18 CTRL MOD. - AUDIO # SPEAKER LEFT FRONT DOOR (WOOFER)
22 RME09 (BN-YE) 18 CTRL MOD. - AUDIO # SPEAKER LEFT REAR
22 RME09 (BN-YE) 22 CTRL MOD. - AUDIO # SPEAKER LEFT REAR AMPLIFIER
23 RME12 (BN-BU) 18 CTRL MOD. - AUDIO # SPEAKER RIGHT REAR
23 RME12 (BN-BU) 22 CTRL MOD. - AUDIO # SPEAKER RIGHT REAR AMPLIFIER
24 DME09 (-) 20 CTRL MOD. - AUDIO # REAR
C240B
1 VME52 (BU) 22 CTRL MOD. - AUDIO # APIM LEFT
1 VME41 (GN-OG) 22 CTRL MOD. - AUDIO # SATELLITE DIGITAL RADIO LEFT EARLY PRODUCTION
2 RME52 (GY-OG) 22 CTRL MOD. - AUDIO # APIM
2 RME41 (BU-BN) 22 CTRL MOD. - AUDIO # SATELLITE DIGITAL RADIO LEFT EARLY PRODUCTION
3 DME45 (NONE) 18 JACK - AUDIO # EXT. AUX IN
4 VMN14 (WH-VT) 22 CTRL MOD. - NAVIGATION # AUDIO OUT (MONO)
5 RMN14 (GY-BN) 22 CTRL MOD. - NAVIGATION # AUDIO OUT (MONO)
6 VME46 (BU-GN) 22 JACK - AUDIO # EXT. AUX IN RIGHT (+)
7 VME45 (BU) 22 JACK - AUDIO # EXT. AUX IN LEFT (+)
8 RME45 (YE-GN) 22 JACK - AUDIO # EXT. AUX IN LEFT (-)
9 VME53 (VT-GN) 22 CTRL MOD. - AUDIO # APIM
9 VME42 (VT-BN) 22 CTRL MOD. - AUDIO # SATELLITE DIGITAL RADIO RIGHT EARLY PRODUCTION
10 RME53 (BN-WH) 22 CTRL MOD. - AUDIO # APIM
10 RME42 (YE-BU) 22 CTRL MOD. - AUDIO # SATELLITE DIGITAL RADIO RIGHT EARLY PRODUCTION
11 VMN01 (BU-BN) 22 CTRL MOD. - NAVIGATION # MICROPHONE OUT
12 RMN01 (GN) 22 CTRL MOD. - NAVIGATION # MICROPHONE OUT
13 * * Not Used
14 RME46 (WH-GN) 22 CTRL MOD. - AUDIO # SATELLITE DIGITAL RADIO RIGHT
15 VDB06 (GY-OG) 20 CONNECTOR - DIAGNOSTIC # CAN BUS MEDIUM SPEED HIGH
16 VDB07 (VT-OG) 20 CONNECTOR - DIAGNOSTIC # CAN BUS MEDIUM SPEED LOW
C240C
1 VME22 (VT-GN) 20 CTRL MOD. - AUDIO # SUBWOOFER/AMPLIFIER AUDIO +
2 RME22 (GN-WH) 20 CTRL MOD. - AUDIO # SUBWOOFER/AMPLIFIER AUDIO -
3 DME22 (NONE) 20 CTRL MOD. - AUDIO # SUBWOOFER/AMPLIFIER AUDIO
4 SME23 (VT-RD) 20 CTRL MOD. - AUDIO # SUBWOOFER/AMPLIFIER ENABLE
5 * * Not Used
6 * * Not Used
7 * * Not Used
8 * * Not Used
1 - 3 of 3 Posts
