SGecko said:
In preparation for winter driving (both in terms of safety and fun!), I'm looking to upgrade my suspension. What are my options for a 2005 'scape XLT? Do I get anti-roll bars? Dampers? Gas shocks? I'm assuming that I will go with:
1. Some KYB shocks to improve stiffness and handling for snowy roads
2. Stiffer springs
3. Good winter tires (Firestone Winterforce UV were installed today).
Any other thoughts?
Thanks,
- sG
Hello SG,
Right now the only KYB shock and strut made for the Ford Escape platform is the KYB GR-2. You will notice a considerable improvement in ride quality vs your stock shocks and struts. I replaced my factory shocks and struts with the KYB GR-2 on my 2009 Escape at 7,000kms because I was not satisfied with the ride characteristics of the stock dampers.
You may want to begin with just replacing the shocks on your Escape to see if the improvement in your ride will be sufficient for your needs. If you feel that stiffer springs are needed after the fact, there doesn't seem to be any firmer springs that retain the factory ride height (either the springs are lower or higher). H&R Special Springs manufactures a lowering spring that is approx. 10-15% stiffer than stock however the height of the Escape will go down by approx. 1.5" (front and rear). Again, you may want to start with installing shocks & struts only to begin with.
The Firestone Winterforce tire is a very good and meaty snow tire which will serve well in snow and rainy conditions.
Let us know how your search goes,
Tom
