Hey folks.... Ive been a member here for a bit... i just had to chance my username b/c i forgot it... so im back...
I do have a question tho... I am planning on spending this years tax return on new tires for my 07 Escape. I know the current tires i am running are LT235/70R16s.... I was looking at a few different one out there.. and i found a couple, but the closest size i could find was LT235/85R16. Is the 70 and 85 a big difference? will they fit on my car?
Thank you for taking the time to read this. I appreciate all feedback.
Later
Kev
Hey megascape... any luck on the alternator skid plate??? and I am totally game for one of your 3/16 aluminum skid plates for the under carriage... thanks dude...
:rockon:
From here LINK
Sidewall Aspect Ratio
Typically following the three digits identifying the tire's Section Width in millimeters is a two-digit number that identifies the tire's profile or aspect ratio.
P225/50R16 91S
The 50 indicates that this tire size's sidewall height (from rim to tread) is 50% of its section width. The measurement is the tire's section height, and also referred to as the tire's series, profile or aspect ratio. The higher the number, the taller the sidewall; the lower the number, the lower the sidewall. We know that this tire size's section width is 225mm and that its section height is 50% of 225mm. By converting the 225mm to inches (225 / 25.4 = 8.86") and multiplying it by 50% (.50) we confirm that this tire size results in a tire section height of 4.43". If this tire were a P225/70R16 size, our calculation would confirm that the size would result in a section height of 6.20", approximately a 1.8-inch taller sidewall.
So if I calculated that correctly the 85% sidewall tires are 1.39" taller rim to tread height.
I can't say anything for certain, I'm just making a guess based on the numbers, but I have a size taller tires on my Escape than are stock, so I'd assume that 1.39" extra would not cause an issue.
2010Escape that website really helped... it gave me opinions of what size to drive and what not to drive.. it was some good stuff...
