1 - 8 of 8 Posts
I'm thinking of buying some snow tires for my rims and making them my permanent winter rims, then buying some new 17 or 18" this summer.
My question: can I take my stock tires that have about 70% tread left (235/70/R16) and put them on my gf's Hyundai Santa Fe that currently has size 225/70/R16 tires? I realize they will be 10 mm wider but I assume this should be ok?
Additionally, has anyone had any experience with any of the following tires:
Michelin X-Ice xi2
Bridgestone Blizzak
General Altimax Arctic
Obviously the General's price point is attractive, but I am definitely considering all three. Thoughts?
Thanks in advance!!
I can answer the first question. I'll be asking the second set sometime in October for myself as I'm looking for a winter set of shoes soon.
The difference is more than just width. The 235 tires are also a little taller. First number is the width. The 70-part of the wheel info tells you how tall the sidewall is relative to the width. 0.70 x 235 = 164.5mm or around 6.48 inches. 0.70 x 225 = 157.5mm or 6.2 inches.
This translates into a taller ride and also some speed reading changes.
Total height
6.5 x 2 = 13 + 16" wheel = 29" wheel and tire
6.2 x 2 = 12.4 + 16" wheel = 28.4" wheel and tire
Speed is based on circumference
29*pi = 91.11inch/rotation
28.4*pi = 89.22inch/rotation
Resulting in a 2% difference in your speedometer... so in your instance, a little faster... I think.
Hope this helps!
P.S. I think someone on here uses the Mich ice tires.
Thank you both very much for the info! Good to know about the speedometer reading and that tire calculator is super handy. I just bought a used 07 escape less than a month ago and I love it, the all wheel drive is awesome and I'm looking forward to throwing some high performance snow tires on!
Oh, and this forum rocks.
So I have s tire swap question as well. When it comes time to trade in for a new Escape (or Mariner...either one), I am gonna put my current Pro Comp rims on it. However, my current rums have no TPMS in them, and I know new Escapes/Mariners have that system. Does it matter whether or not I run wheels without TPMS?(other than I won't get a warning on my dash when the tires are low on air)
I run 255 55 r18 with no clearance issues at all, and could probably go wider if I really wanted to.
And I don't have sensors either, and I've had no issues in the year on the wheels.
I think the TPMS can be added to aftermarket wheels. I have been looking (casually of course) and can not find where I read that. Maybe in a magazine. I at first thought it was on another Ford site...now I don't know. :shrug: :doh: If I find it, I'll post it up. As for what it does...turns on your dash light.
The lack of TPMS just makes my light stay on for a few seconds after startup. No big deal, really. I check my pressure regularly, so I'm not worried about sensors.
1 - 8 of 8 Posts
