Out transmissions have a drain plug? I always thought that you were supposed to remove the pan, which gives you access to the filter. Like with all my previous vehicles, I plan on doing a change of flush at 30k miles since I always do the first one sooner than recommended. Those CD4E's are actually not that bad as there are plenty of them with lots of miles.Mantruck101 said:Speaking of the tranny drain plug, when are all of you planning on changing the transmission fluid in your 2009-2011 Escapes with the 6-speed autos?
We change the tranny fluid every 30K in my parents' 2001 V6 because of the less than stellar reliability record of the CD4E. So, do we trust the 6F35 to go longer than 30K between fluid changes? I will likely turn 30K miles in the next week and need to have my Escape serviced anyway. Should I have them flush the transmission fluid too?
I have no idea where the tranny drain plug is or if there even is one. I suspect that there is one since Ford recommends changing the fluid @ 150,000 miles.amdgamer said:Out transmissions have a drain plug? I always thought that you were supposed to remove the pan, which gives you access to the filter. Like with all my previous vehicles, I plan on doing a change of flush at 30k miles since I always do the first one sooner than recommended. Those CD4E's are actually not that bad as there are plenty of them with lots of miles.
I hope someone clarifies this as i'm curious myself. I've never seen a modern car with a permanent transmission filter, as every one one of them had a removable one that was accessible by removing the pan. I know that the manual for my 2011 states that replacing the tranny filter is not necessary, and doesn't seem to clarify.kmoose said:I thought these had "permanent filters" and all you do is drain, refill, drain, refill, drain, refill to get new fluid. Am I wrong?
As for timing, 30,000 miles / 48,000km in my opinion is the time to change fluid in a transmission, regardless of how reliable it is. If you are using fully synthetic, like my wife's car, they recommend every 36,000 miles or 60,000km....so that should give you an idea of the maximum time to let it go.
That's it, 11 mm plug with pipe threads. I drained and refilled mine at 15,000 miles and plan to continue that practice. The fluid was dark and smelled a little burned so 4 fresh quarts should help things out. I don't trust most shops with their power flush systems. The six speed is supposed to be picky about the fluid used and most places don't seem to know what LV fluid is. I had to go to the dealer to buy some.thom said:Mine has 68000 kms. And if I can find the drain plug, I plan on changing the fluid.
I do see a small bolt head under the plastic shield but it looks too small to be a drain....thats why I was asking.
I just read the proceedure in the ford manual. It says to drain and fill 3 times (running and shifting for 3 min in between drain and fill) to get all the fluid out of the torque converter.hmiwb said:That's it, 11 mm plug with pipe threads. I drained and refilled mine at 15,000 miles and plan to continue that practice. The fluid was dark and smelled a little burned so 4 fresh quarts should help things out. I don't trust most shops with their power flush systems. The six speed is supposed to be picky about the fluid used and most places don't seem to know what LV fluid is. I had to go to the dealer to buy some.thom said:Mine has 68000 kms. And if I can find the drain plug, I plan on changing the fluid.
I guess it depends on what year it is. The CD4E trans really needs it more often than the owner's manual says. If that is what you have, then yes, It should be done. The six speed seems to be more durable. The manual from my 2010 says no need to change it until well over 100,000 miles. I plan on doing it well before then.david said:that`s funny my dealership mechanic recommends automatic transmission fluid and filter changes every 40,000 kilometers. :shrug:
Found this post here viewtopic.php?f=8&t=23110&p=325388&hilit=Mercon+LV#p325388money_man said:mine looked like used motor oil the first time I changed it out at 60k miles. a purplish color is what you need to watch for because that's normally the color of the fluid if aluminum is mixing into it. Buy a 12pk of the mercon LV (used in the 6F35) and do three drain/fills and see how it works after.
I read somewhere that ford explained that the 6F35 uses carbon fiber clutches and that's what discolors the fluid. Make sure you have the newest software available. There is a TSB for a hard 1-2 shift and shift flaring going from 2-3
