1 - 3 of 3 Posts
2011 2.5 FWD Silver Escape
Hi all,
My 2011 was forced the other day, so now the door lock is damaged so the door didn't lock with the fob or the interior lock button; since it is already damaged it could be easily opened again by another thief I took the door panel off to remove the rod so the lock could actually lock and if someone tries to force the cylinder again they wont open the door; in the process as Im obviously still angry and stressed I couldnt remove the rod the proper way so I broke the plastic piece from the cylinder that hold the rod assuming that a new cylinder will have a way to attach the rod.
My question here is, Are there upgraded door lock cylinders from aftermarket sources? Or if I replace the door lock I will be stuck again with an OEM that can be easily forced again?
Asking since I recall that whenthe cylinders weren't integrated to the door handles owners down here replaced the OEM with Mul-T-Lock or even Yale cylinders.
Im also installing an afterkarmet alarm system ASAP.
Automotive lighting Cable Font Tool Auto part
Land vehicle Vehicle Automotive tire Bumper Tire
At least they didn't break a window, or jack the ignition. Hopefully they won't be back if they didn't get anything.
buying an alarm system, you probably need to be sure it compatible with a PATS. I would recommend a paging alarm
This happened in a public parking lot at the beach so as long I dont go back there they wont come back after my car; I did disable the door cylinder to avoid new attempts by a new thief if they see it is already damaged.
I will keep looing for reinforced cylinders and make sure the alarm will work with PATS as I won't disable that option either.
1 - 3 of 3 Posts
