So this truck is a 2002 escape with the 3.0. I went to autozone to check the codes and it threw out like 3-4 codes related to a vacuum leak and cylinder 1 misfire. truck runs very rough. when idling, it wont rev past 4000 rpms. I already read the thread on how to change the spark plugs and cop. What I need help on is where to look for this vacuum leak. Thanks in advance.
mine was leakingfrom behind the motor where the line splits to the ac/heater, and also in the cab behind the glove box there is a conection from the under hood line to the ac/ heater system.. I also replaced all other lines just for good measure. i think between ford and autozone i spent $50.00
my escape 3.0 xlt 4x4 has run great since
First, what are the codes? Mileage? If it's throwing 3-4 vacuum related codes, that is likely causing the misfire also. When not in a drive gear, you won't be able to rev past 4k due to the rev limiter. That's functioning as it should.
oh, wow. I didnt know about the rev limiter. Mileage: 197*** (for a 2002). Ill try to get the codes from Autozone. Thanks for all the replies. Ill get back to u guys.
