In case you're wondering what is shown in a Vehicle Health Report in Sync 2.0, here's my report from today. The formatting is messed up but it gives you an idea of what is tested and displayed. It's much easier to read online.
Vehicle maintenance information as of today, April 21, 2009:
Engine, Transmission & Emissions
OK
About the Engine, Transmission & Emissions
Your engine's power is delivered to the driving wheels by the transmission. The transmission uses gears, electro-hydraulics, and sensors to optimize vehicle performance.
An on-board computer monitors engine performance, adapts automatic transmission shifting (if equipped), controls emissions and balances performance with fuel economy.
If equipped, your vehicle's 4WD or AWD system delivers engine power to all four wheels through the transmission, transfer case, and driveshafts.
Just as with your engine's on-board computer, an on-board computer monitors the 4WD/AWD system and reports to you.
Brakes & Suspension
OK
About the Brakes & Suspension
Your vehicle's Anti-lock Braking System (ABS) helps maintain steering control during emergency stops by keeping the brakes from locking.
Your vehicle's suspension supports the weight of the vehicle, maintains tire contact with the road and isolates the vehicle's occupants from road bumps.
If equipped, the AdvanceTrac with RSC system provides stability enhancement features for certain driving situations. If equipped, your vehicle's air suspension improves ride and handling. If equipped, the Trailer Brake Controller (TBC), when used properly, helps ensure smooth and effective trailer braking.
On-board computers monitor these systems and report to you.
Restraints & Driver Assistance
OK
About the Restraints & Driver Assistance
Your vehicle is equipped with a restraint system comprised of safety belts and an air-bag Supplemental Restraint System (SRS).
Your vehicle's Belt Minder feature reminds you and your passengers to buckle your safety belts.
Your SecuriLock™ anti-theft system prevents the vehicle from starting without your key.
A Reverse Sensing System (RSS) (if equipped) warns you of obstacles near the rear bumper when backing up. Lincoln vehicles have optional adaptive cruise control, which automatically adjusts speed to maintain a proper distance between you and the vehicle in front of you in the same lane, and optional Intelligent Key access, which automatically unlocks your vehicle when you approach and starts it without putting a key in the ignition lock cylinder.
Checks, Fluids & Filters
OK
About the Checks, Fluids & Filters
Your vehicle's on-board computers monitor the engine oil pressure and coolant temperature, washer fluid level, and fuel and air intake systems.
As an added safety feature, your vehicle may be equipped with a tire pressure monitoring system (TPMS) that illuminates a low tire pressure indicator light when one or more of your tires are significantly under-inflated.
Be sure to use only recommended fuels, lubricants, fluids and service parts conforming to specifications when maintaining your vehicle. Motorcraft parts are designed and built to provide the best performance in your vehicle.
Scheduled Maintenance
Review Scheduled Maintenance for 2009 Ford Escape
7,500 Miles: Scheduled Maintenance
Your vehicle has been driven 2,093 miles (actual). In approximately 5,407 miles, you should consider the following recommended scheduled maintenance.
Change engine oil and replace oil filter (Up to 5 quarts of oil. Perform at specified mileage interval or every 6 months, whichever occurs first)
Perform multi-point inspection
Rotate and inspect tires; check wheel end play and turning noise
0
Dealership Coupons
View service and accessory specials from your dealership
You have 0 dealership coupons as of April 21, 2009
There are no dealership coupons currently available for 2009 Ford Escape. Dealership coupons are updated often, so please check back soon. Dealer Inspection Items
View needed service(s) identified during your last dealership visit
You have 0 dealership inspection items as of April 21, 2009
Retrieving dealership information
There are no open dealer inspection items. Only items identified by your preferred dealership are displayed. If you had your vehicle serviced elsewhere, any inspection items the technician(s) may have noticed will not appear in the Vehicle Health Report.
OK
Brakes & Suspension
OK
OK
OK
0
Dealership Coupons
