Check the oil level?
Oil is fine.Check the oil level?
it does it all the time.mine does the exact same tapping/knocking...basically they say it is the character of the motor.
some techs suggest checking the torque of the camshaft for loose bolts (seems common issue) in some models.
Can you post a video please? just wanna compare it to mine.it does it all the time.
my ford mechanic brother does say this isa normal sound for the engine.
You would of thought ford would have fixed the camshaft bolt issue when they redesigned the heads for vvt.
YupCan you post a video please? just wanna compare it to mine.
I agree thank you.thanks for postig the videos, the 2nd video seems like a normal duratc V6 engine noise which is a bit noisy engine in general. the slight tapping, tick tick tick sounds exactly like mine.
glad you fixed your issue![]()
