1 - 1 of 1 Posts
basic socket set needed, maybe a right angle socket adapter for a drill would make getting at the steering column pivot bolt easier to unthread, t45 socket
i had a random Electronic Power Steering (EPS) assist failure which wasnt the fault of the torque sensor, a common problem on many of the ford and other makers vehicles, mine being a 2009 ford escape. the electric assist motor would randomly just quit working. it would be very hard to turn when driving in low speeds as in a parking lot. some people have a Power Steering Code B2278 : EPAS there was no steering wheel vibrations or random movements to either side. it would just quit working with no warning. the only way to revive it would to restart engine until it came back to life, sometimes after one restart or multiple restarts. i got a used one from wrecker from a 2010 model, pulled it out myself for $140can. u can use any column from 2008 to 2012 ford escape. i will be doing a tear down on the old control module, im thinking the problem is in the circuit board and not the motor itself
1 - 1 of 1 Posts
