This video shows how to rotate the tires on an Escape while also passing on some useful info (such as back saving tips).
Why would someone want to rotate their own tires? Here are some of my reasons…
1) Careless installers chipping the chrome cladding with impact wrench
2) Careless installers stripping the threads on nut and stud with impact wrench
3) Careless installers over torqueing nuts with their gorilla impact wrench
4) Installers won't check for and remove pebbles, glass etc. from treads
5) Careless installers may not insure wheel center hole is fully mounted on hub - and then torque it down with impact wrench. (this actually happened to me and at a Ford dealer no less - that dealership closed long ago. Went to Flagler Ford to have new carry-in tires mounted and balanced on my 1993 Ford. Was driving off and heard this loud metallic snap. Then, the wobble came. Went back to the shop and the wheel was loose. The forces of driving had made the wheel center hole snap back onto the hub.
6) Careless installers losing lug nut and replacing it with correct size but wrong style lug nut making mismatched set.
7) No BS sales pitches about needing, shocks & struts inhibitor service, brake pad deionizing service, alternator fluid change, TPMS Sensor dilation service, new Johnson rod, etc.
8) DIY permits me to clean backside of wheels and the holes for the lug nuts (which are hard to clean with lug nuts installed)
9) No waiting and waiting and waiting in customer lounge for something I can do in under 2 hours.
10) I save a couple of bucks and get some exercise.
[mod]Used my moderator superpowers for good and embedded the YouTube. - Charles[/mod]
