I was told it is part of the rocker cover, however, I can not find a picture of a replacement part that looks right.
I know the oil filler cap was off when I took this photo ... I was in the middle of an oil change at the time.The rocker cover is also called the valve covers. You are missing the oil filler cap.
I had oil spewing all over the place!There is a whole lot of stuff going on in this image, what specifically? There are 2 cam/valve covers (one missing something and can see the timing chains), motor mount, a coolant hose, a whole lot of oil and gunk, and so on.
Yes, the oil filler cap was off in the pic because I was in the middle of an oil change when I noticed the big hole in the rocker cover (front part).
It's too cold to work outside here in Ontario, so I have temporarily patched the hole with JB Weld putty. Waiting on better weather to comelplete the repair.I had oil spewing all over the place!
That's when I noticed the big hole in the front section of the rocker cover!
I agree with you Dwight, I think somebody dropped something on it, or hit it with something… The only thing that I would be concerned about is the hunk of plastic is now down inside of thereI think if something came loose in the upper drive train, the engine would be making a horrible noise and failing in short order. Iv'e see connecting rods punch holes in the block, but yet to seen anything punch a hole in the valve cover.
I think your JB Weld probably fixed it blowing oil, Shari.I had oil spewing all over the place!
I would say first thing you need to do is pull off the plastic cover that covers the top of the engine, and see how much of that valve cover damage extends beyond what you seeI was told it is part of the rocker cover, however, I can not find a picture of a replacement part that looks right.
