I recently switched from Galeon to Firefox, as Galeon would choke when I opened more than ten tabs. I found this 'hack' to get around the fact that my Outlook Web Access login page told Firefox not to suggest remembering my login information. This should work for all login forms and other fields that have disabled autocomplete. The bar still pops up asking if you want Firefox to remember your password, so you can still decline if you want to.
Code:
* Shutdown Firefox
* Backup the file PATH_TO_YOUR_FIREFOX_INSTALLATION/components/nsLoginManager.js.
* Edit PATH_TO_YOUR_FIREFOX_INSTALLATION/components/nsLoginManager.js with your favorite text editor and find the following lines:
Code:
if (element && element.hasAttribute("autocomplete";) &&
element.getAttribute("autocomplete";).toLowerCase() == "off";)
return true;
On the GNU/Linux version of Firefox 3 Beta 5 this code is inside the private method _isAutocompleteDisabled, on the Windows version of Firefox 3 Beta 5 this code can be found inside the local helper function autocompleteDisabled which is part of the private method _onFormSubmit.
To let Firefox password manager always remember passwords those "autocompleteDisabled"-methods have to always return the value false.
All you have to do to achieve this is remove the lines above or comment them out like this:
Code:
// if (element && element.hasAttribute("autocomplete";) &&
// element.getAttribute("autocomplete";).toLowerCase() == "off";)
// return true;
* Save your changes and close the editor.
* Restart Firefox - Firefox password manager should now always remember passwords ignoring the autocomplete="off" attribute.
