did i melt the manifold cats
If you're asking, I'm wondering what the whole story is.
If the bottom cat was replaced because it was plugged, there's a good chance one of the two upper cats started breaking up, but they can also melt together and become a blockage. Misfires will overheat these cats so fast you won't believe it.
As Tom said, removing the upper O2s and running it will tell you if you have a stuffed cat. The opening of the O2 sensor isn't very big, but if the cat is mostly blocked, then the small opening of the removed O2 will give it more power, and if you feel a lot of puffing coming out of the hole, then the cat is blocked.
I bought an 05 for "parts" because it had many issues and was undriveable (long story). My 05 had a completely stuffed up bottom converter, so bad the car would barely run (and it sounded like a Hoover running beneath the car). I removed it and bashed it out hollow. Other than a slight change of exhaust tone, it runs just fine. Whether it runs better is something I can't tell you because I never hot-footed this car, but it most certainly did
not run worse.
But, after I hollowed out the lower cat, I got an upper cat efficiency code. Seems like the upper cat's innards blocked the lower cat. I was lucky in that the upper cat didn't melt down and plug up, but it did break up and shed some material downstream.
John
