1 - 8 of 8 Posts
I am coming up for a brake change. While I am at it I want to chage out the front rotors just for the fact that they are all rusted out (obviously not the break path, except for when it sits for a day or two then it rusts) I just want a clean look and possible extra stopping power (slotted). Anyone have any ideas????
Not too cheap, but dont wanna break the bank....
THANKS :hi:
From what I've read, blank rotors are most often recommended for daily drivers. I've read that the Brembo blank rotors are quite good. I would like to replace the rotors and pads on my Escape, so wouldn't mind hearing others' input on what works and what doesn't.
True I could drill my own holes, but I would have look for a pattern to drill. Wish I had a lathe to add slats. I check you all up dated when and if I change rotors.[align=][Align=][/align][/Align]
Thanks, so you noticed stopping what about brake dust?
if your worried about brake dust, i would install wheel shields that bolt between the rim and rotor hub they look great and you can paint them. i havent found any yet for cheap if anyone does met me know
1 - 8 of 8 Posts
