Certifit Dark Gray front bumper cover & aftermarket headlights.
SEM Bumper Coater 39173 Dark Smoke >>> side door/rocker panels & rear bumper cover.
Dark Smoke is a pretty good match to the aftermarket bumper cover.
39183 Medium Gray might be a better match, but I didn't try that shade as the auto paint store didn't have it.
As a test, I tried 39583 Light Charcoal on the plastic panel behind the RH Fr wheel, but it wasn't quite dark enough.
The bumper coater has held up well over the last six months. I use a bubble brush carwash almost every week and sit on & put my foot on the rear bumper cover often: there are no scratches or chips in the coating. Prep was to thoroughly wash the car at the car wash and scrub the plastic with a scotch brite pad. Let the plastic dry, then thoroughly wipe it down with a clean cloth saturated with acetone. Mask. Wipe the section to be sprayed with a tack cloth to remove any dust. Then spray several coats of bumper coater. Since I had a can of Light Charcoal that I didn't want to go to waste, I used that as a base coat for the rear bumper cover, then top coated with Dark Gray.
note: the sun is to the right, so the Fr bumper cover plastic looks lighter than the painted plastic, but it's actually the same color or maybe slightly darker.
