by Captain Chris - December 8th, 2020, 2:27 pm
bangster wrote:They have a PTU that always sends power to the rear. There is a coupling device in the rear. The early gen 1 had the switch between AUTO and ON. In auto, on demand (slip or high throttle input) it would split torque mostly to the front unless slip or high throttle input, then be up to 50/50. In On it was locked at 50/50 (so whatever coupler is in the rear is locked and no slip).
OK, si I just got an '08 Mariner 4WD: is that an old-fashioned hard connection driveshaft to the rear wheels?
Seller said he 'recently' (3-4 K miles) had maintenance done on the transfer case, but I haven't fully absorbed all the dox in glove compartment.
Do you have any knowledge/experience with just pulling out that shaft, and reverting to basic FWD?
TIA
