Forscan As-built sheet
Postby thesavo - April 12th, 2018, 7:14 am
I think we need an EMT focused As-built spreadsheet. All other other cool forums have one that that lists the As-built module codes and values.
I'll update this post with a Google sheet that has them broken down by module. It should also include a tab for common changes that involve value changes in multiple modules.
I know our little community isn't as active as others in this field. But I can't be the only one disappointed that this doesn't exist yet.
*disclaimer : use this information at your own personal risk. If you damage your vehicle with information, it's not our fault.
Jump to post 8 for an update.
Gen 2 EMT Google Sheet
https://docs.google.com/spreadsheets/d/ ... sp=sharing
Other Sheets
2008-2010 F250 SuperDuty
2011-2014 F-150 As-Built Options
FORScan 2015-2018 F150s
FORScan 2016 Super Duty
FORScan Codes for 2017 Super Duty
FORScan_2011-2019_Explorers - iCloud warning.
2013+ Flex FORScan
2GFusions - Ford As-Built Data Mods (DanMc85) : Spreadsheet
FORSCAN Codes - S550 Mustangs
Forscan Guide
Re: Forscan As-built sheet
Postby jsnali13 - April 18th, 2018, 11:09 pm
Would love that
Sent from my SM-N950W using Tapatalk
jsnali13
My vehicle: 2005 Escape XLT
Postby Jeff146 - April 19th, 2018, 9:44 am
I would love them too!!
Jeff146
Postby ac316scu - May 16th, 2018, 5:04 pm
Any progress on this? Just downloaded Forscan and been looking for something like this
Sent from my SAMSUNG-SM-G935A using Tapatalk
MECP Advanced Certified
NYS Motor Vehicle Inspector
ac316scu
My vehicle: 03 Mustang & 11 Escape
Postby thesavo - May 16th, 2018, 5:51 pm
Right now, I have to build the sheet and life has been a bit in the way.
Sent from my SM-N950U using Tapatalk
Postby vmariner - June 1st, 2018, 3:33 pm
Спасибо, Thank Aquil0n https://www.drive2.ru/users/aquil0n/
Caution! Achtung! Внимание!
Все имеющиеся на данный момент в распоряжении коды, включающие-отключающие функции в авто. Собрано из наработок пользователей форума ФордФокусКлуба, pavel700777 и nikolna
Рекомендую публиковать отсюда на сторонние форумы.
Доработка ELM 327
www.drive2.ru/l/3579938/
forffclub.narod.ru/index/0-2
Памятка по использованию адаптера ELM327
ATL1-включаем перенос строки
ATSPB -среднескоростная шина
ATSP6 -высокоскоростная шина
ATSH – установка заголовка(адреса, куда обращаемся)
21 – читать из авто
3b – запись в авто
2100 – читать первую строку(2101-вторую строку и т.д.)
Коды конфигурации Эскейп 2008:
1) 733-01-01 Температура наружного воздуха
00 Показания наружной температуры на панели ВЫКЛЮЧЕНЫ
01 Показания наружной температуры на панели ВКЛЮЧЕНЫ
<atl1
<atspb
<atsh733
<3b00 01 — включаем температуру
<2100 — проверяем на всякий случай
Важно: температура отображается в системе измерения авто, то есть Цельсиях или Фаренгейтах.
2) 7А6-02-01 Название авто при включении зажигания на верхней панели
00 Ford Escape
01 Ford Escape Hybrid
02 Mercury Mariner
04 Mazda Tribute
07 FORD ESCAPE HYBRID PREMIUM SOUND
<atl1
<atspb
<atsh7a6
<3b01 00 или 01 или 02 или 04 — выбираем по вкусу
<2101 — проверяем на всякий случай
3) 727-03-01 Четные частоты радио
0000 Нечетный шаг частот
0001 Четный шаг частот
<atl1
<atspb
<atsh727
<3b02 0001 – включаем четные частоты радио
<2102 -проверка
4) 726-03-01 Дневные ходовые огни + ПТФ
0с00 ДХО и ПТФ неактивны
0d00 ДХО неактивны, ПТФ активны
0e00 ДХО активны, ПТФ неактивны
0f00 ДХО и ПТФ активны
<atl1
<atspb
<atsh726
<3b02 0с00 или 0d00 или 0е00 или 0f00 – включаем, что нам нужно
<2102 -проверка
5) 726-02-01 Система контроля давления в шинах
Читаем первое слово( первые 4 hex-символа), переводим в двоичное число, далее читаем это двоичное число СПРАВА-НАЛЕВО, седьмой символ("по программерски" считаем шестой, то есть с 0 начиная,0123456) переводим в 0, получившееся число преобразуем обратно в hex и прописываем обратно всю строчку с изменениями.
Update: проверено на указанной конфигурации 0040, читаем 1000000, обнуляем шестой бит, прописываем, лампочка TPMS гаснет.
было стало
0040 0000
<atl1
<atspb
<atsh726
<3b01 смотри таблицу
<2101 -проверка
6) 720-01-01 Связь с системой полного привода
При физическом отказе от полного привода, при неисправности системы полного привода, когда на панели загорается значок «виляющей машины» этот значок можно потушить.
Читаем первое слово( первые 4 hex-символа), переводим в двоичное число, далее читаем это двоичное число СПРАВА-НАЛЕВО, восьмой символ переводим в 0( считая "по программерски", с 0,то есть 01234567,символ будет седьмой), получившееся число преобразуем обратно в hex и прописываем обратно всю строчку с изменениями.
было (Х-ваши символы) стало (Х-ваши символы)
ХХ8Х ХХ0Х
<atl1
<atsp6
<atsh720
<3b00 ХХ0Х ХХХХ ХХ отключаем значок неисправности полного привода
<2100 -проверка
7) 720-01-01 Показания компаса на верхней панели
Актуально для обладателей салонного зеркала заднего вида с автозатемнением, где и находится сам модуль компаса.
Строка выглядит так ХХХХ 4ХХХ ХХ-компас неактивен
Срока выглядит так ХХХХ 6ХХХ ХХ компас активен
Символы Х — ваши, при активации компаса не меняем
<atl1
<atsp6
<atsh720
<3b00 XXXX 6XXX XX включаем компас, Х-ваши символы, не меняются
<2100 для проверки
8) 726-03-01 Переключение контроля целостности ламп с двухнитевого режима на однонитевый.
Делается для того, чтобы после доработки задних фонарей ( добавления желтых поворотников) новые лампы поворота моргали с нормальной частотой. Про доработку фонарей подробно расписано тут.
3300-однонитевая лампа, 0f00 (или другое значение из пункта 4 — см.выше)-двухнитевая лампа
Отдельно отмечу, что ДХО, включенные ранее прописыванием 0е00, остались активными.
<atl1
<atspb
<atsh726
<3b023300 — контроль целостности лампы с одной нитью накаливания
<2102 -проверка
Как говорится, всё на свой страх и риск и всё такое, ответственности не несу. Информация собрана для ознакомления
P.S. Разыскивается информация о:
— переключении с помощью адаптера миль в километры и фаренгейтов в цельсии;
— переключении проверки целостности ламп задних указателей поворота с двухнитевого режима на однонитевый ( для переделки задних поворотников на желтый цвет)-решено
Mileage 220,000 km
I in facebook https://www.facebook.com/ViktosLub
vmariner
My vehicle: 2008 Mercury Mariner 4*4 2.5
Postby bogiediver - November 5th, 2018, 4:42 pm
thesavo wrote:Right now, I have to build the sheet and life has been a bit in the way.
Any joy on this for the '08-'12 Escapes...
Some info out there for newer, but for us old bodystyle - not so much...
- bogie
http://www.mchenrycountyroadpirates.org
Currently have:
- 2012 Ford Escape XLT 4X4 (110,000 + miles)
- 1931 Ford Model A Roadster
- 2011 HD Ultra Limited
- 2001 Mazda Tribute ES 4X4 with 195,000 miles sold
- 2006 HD Ultra Classic (over 110,000 miles) - sold
bogiediver
My nickname: bogie
My vehicle: 2012 Escape XLT 4X4
Postby thesavo - November 22nd, 2018, 12:52 am
Sorry for the long delay everyone. Life happens.
I have made a blank sheet in my Google account. I added a link in post 1. As I find codes and have the chance to test them, they will go in.
Right Now it is filled with empty tabs for each module. 2nd gen doesn't have all the lines/rows that the newer and popular vehicles have. Since third gen is so different, I would probably start a separate one for them. However, I think that many fusion/Focus AS-built codes may be compatible. Since I have an 08, I won't be testing those.
Anything that I add to the sheet, that I cannot or will not test will be marked as "untested by steward"
Please feel free to post your own findings in this thread. If anyone can confirm the findings in the other common sheets, that would be nice as well.
If anyone can translate the Russian for me in post 6, that would be a great start.
I will also be making some youtube videos dedicated to forscan. For now, they will intro and walk-through videos. The first video will be pairing my ODBLink MX to my Surface book.
Postby thesavo - June 1st, 2020, 9:32 am
Hi all, sorry for the long delay.
Since there are already many other sheets dedicated to other models, there are equally as many formats. What format would we like best?
I would like to conform it others so as people look between ours and others there is some concurrency.
I picked one that I think looks best, but would like input from others.
Here it is again.
Also, it would be nice if we can get it listed on this page below.
https://ohptools.com/blogs/news/list-of ... th-forscan
Postby zafar - February 11th, 2021, 4:28 am
[quote="vmariner"]Спасибо, Thank Aquil0n https://www.drive2.ru/users/aquil0n/
Доработка ELM 327
http://www.drive2.ru/l/3579938/
21 – читать из авто
3b – запись в авто
<atl1
<atspb
<atsh733
00 Ford Escape
02 Mercury Mariner
04 Mazda Tribute
<atl1
<atspb
<atsh7a6
<atl1
<atspb
<atsh727
<2102 -проверка
<atl1
<atspb
<atsh726
<2102 -проверка
было стало
0040 0000
<atl1
<atspb
<atsh726
<2101 -проверка
ХХ8Х ХХ0Х
<atl1
<atsp6
<atsh720
<2100 -проверка
<atl1
<atsp6
<atsh720
<2100 для проверки
<atl1
<atspb
<atsh726
<2102 -проверка
— переключении проверки целостности ламп задних указателей поворота с двухнитевого режима на однонитевый ( для переделки задних поворотников на желтый цвет)-решено[/quote]
Hi,
I have 2012 Ford Escape XLT 3.0L
Do you have FORScan Spreadsheet?
I want detail of TPMS how it is working.
zafar
My nickname: ZAFAR
My vehicle: 2012 FORD ESCAPE XLT 3.0L
My vehicle's name: 2012 FORD ESCAPE XLT 3.0L
Users browsing this forum: No registered users and 20 guests
