Adding cruise control to a 2005 2.3 with manual trans?
Postby nickaa827 - February 22nd, 2021, 4:39 pm
Is it possible to add cruise control ("speed control") to a 2005 xls 2.3 with manual trans? It did not come with it. Could it be as simple as buying the buttons and plugging in a harness into the (crooked) steering wheel? (Thanks previous owner...)
nickaa827
Re: Adding cruise control to a 2005 2.3 with manual trans?
Postby bangster - February 22nd, 2021, 5:24 pm
While it wasn't standard, it was available in the 66B Convenience group, so it should be possible to add, but it is much more than just the wheel, it has a servo/actuator, and not sure how much of the required wiring exists, clock spring, etc.
Nav (boo), Power Liftgate
bangster
E-C LEVEL 6
My vehicle's name: magnetic
Postby bluto - February 23rd, 2021, 1:09 am
It looks like the 05-07 wheel could be modified to add the switches. It would be easier to swap with one that has the cruise control buttons on it already. The clock spring is probably the same as it has to be present for the horn button and the airbag. That is probably the easiest part. Then you have to figure out how to wire up the servo. And finally enable Speed Control in the PCM. These threads should help a little:
https://www.escape-city.com/viewtopic.php?f=12&t=17484
https://www.escape-city.com/viewtopic.php?f=13&t=24527
Current: 2008 Escape XLT
Previous: 2002 Tribute ES V6
bluto
E-C LEVEL 3
My vehicle: 2008 Escape XLT
Postby nickaa827 - February 23rd, 2021, 1:13 am
Bluto, thank you for the reply. I was not aware of these threads even though I tried to search the forum before making this thread. Thank you! I'll check it out.
nickaa827
Return to Electrical Mods
Users browsing this forum: No registered users and 18 guests
