Part Number Requests
Re: Part Number Requests
Postby thesavo - July 31st, 2017, 8:57 pm
2.5 gas or hybrid?
Sent from my SM-N910V using Tapatalk
thesavo
E-C LEVEL 6
My vehicle: 2008 Mariner Base
Postby MuadDeeb101 - December 6th, 2017, 5:35 am
TPMS Part Number.
I have an 2008/2009 Escape Limited and would like to buy TPMS sensor. I bought some, but they did not work. I bought the activation tool from Ford as well. So I would like to find the original spare part. If you need my VIN, PM me please. Thanks a lot guys.
MuadDeeb101
My nickname: MuadDeeb
My vehicle: 2008 Escape 3.0 V6 Limited
Postby SNCF - March 3rd, 2018, 1:41 pm
Hello
I have got Ford Escape 2005 3.0 AWD 45000miles odometer
VIN 1fmyu93135kd52352
I do not drive much - about 5000miles per year
After 10Years without any real problem i think to change some maintenance.
Engine oil 5w20 Motorcraft Synthetic Blend + filter i change every year
Oil in Automatic transmission i have changed 5years ago and it looks fresch light magenta color. Used Quaker State Mercon ATF.
Maybe it is time to change ATF
Is there a filter in ATF?
Now i can not find this type of oil, only Mercon V or Mercon SP in shops
in car manual there is written: do not use Mercon V
Mercon was mineral oil and here:
http://etereman.com/blog/ford-transmiss ... ord-escape
they say better is synthetic
Maybe I should also change belts in engine?
Greetings
SNCF
My vehicle: 2005 Ford Escape XLT 4WD V6 3l
Postby nx_2000 - March 11th, 2018, 6:49 pm
2008-12 Escape question: You know those clear stickers at the bottom of the rear doors meant to protect the fenders from rock chips? What the hell are those things called? Mine are starting to yellow and I want to replace them.
nx_2000
My vehicle: 2012 Ford Escape XLS
Postby Staphn - March 27th, 2018, 5:52 pm
I broke one of the intake plenum bolts on my '10 Mariner, the ones with the sleeve around them. Any idea what the part # is?
Staphn
My vehicle: 2010 Mercury Mariner Premier
My vehicle's name: Maxine
Postby thesavo - March 27th, 2018, 10:06 pm
Staphn wrote:I broke one of the intake plenum bolts on my '10 Mariner, the ones with the sleeve around them. Any idea what the part # is?
Which bolts? V6 I presume?
thesavo
E-C LEVEL 6
Postby willi2307 - April 1st, 2018, 11:56 am
tmcphail wrote:I can look these up on command if anyone needs this info !
If I ask for a VIN # it's because I need it to make sure I give you the correct part number for your specific vehicle.
Moderator Message:
Added VIN message - RobtRoma
Hey what is the pcm part number for 1FMCU9E74AKC98498
willi2307
My nickname: Will
My vehicle: 2010 ford escape limited 2.5L
Postby thesavo - April 1st, 2018, 2:41 pm
@willi They may need the tear tag number too.
It will look something like this.
Just a heads up Image
thesavo
E-C LEVEL 6
Postby Staphn - April 2nd, 2018, 2:15 pm
thesavo wrote:Which bolts? V6 I presume?
THANK YOU! And yeah, the V6. I guess I should have specified that before. It's one of the 8 or 9 bolts holding the intake plenum on to the engine. I over-torqued it and it snapped off. I should really probably invest in a smaller, much more precise torque
wrench...
Edit: okay I think I see which part # it is. Is it 9Y450?
Out of curiosity, is there a place I can find more of these schematics for the rest of the car?
I'm also looking for the specific part # for the driver's side weather stripping. I know I can get generic stripping from an auto parts store, but I'd rather it be the exact one, so it matches the other door wells.
Staphn
Postby thesavo - April 2nd, 2018, 3:18 pm
wrench...
Fordparts.Com and Tasca Ford parts
thesavo
E-C LEVEL 6
PreviousNext
Return to Part Numbers
cron
