Part Number Requests
Re: Part Number Requests
Postby ITBland - April 3rd, 2018, 8:51 pm
nx_2000 wrote:2008-12 Escape question: You know those clear stickers at the bottom of the rear doors meant to protect the fenders from rock chips? What the hell are those things called? Mine are starting to yellow and I want to replace them.
Left: 8L8Z-99292A23-A
Right: 8L8Z-99292A22-A
Called: Shield in Body Mouldings
https://parts.ford.com/shop/en/us/shield-6321553-1
ITBland
My vehicle: 2010 FEH
Postby ITBland - April 3rd, 2018, 9:09 pm
MuadDeeb101 wrote:TPMS Part Number.
I have an 2008/2009 Escape Limited and would like to buy TPMS sensor. I bought some, but they did not work. I bought the activation tool from Ford as well. So I would like to find the original spare part. If you need my VIN, PM me please. Thanks a lot guys.
2008 is 6F2Z-1A189-A
2009 is 9L3Z-1A189-A
Try https://www.fordpartsgiant.com, put in VIN and see which one is correct. (Ford parts will only give you 1A189)
ITBland
Postby ITBland - April 3rd, 2018, 9:44 pm
SNCF wrote:Hello
I have got Ford Escape 2005 3.0 AWD 45000miles odometer
VIN 1fmyu93135kd52352
Is there a filter in ATF?
At Ford Parts, when you click on "Other Filters", there is a transmission screen, see: https://parts.ford.com/shop/en/us/screen-assy-7837603-1
The full part number would be: F3RZ-7A098-AA or Motorcraft FT124, and (I think) you need this gasket https://parts.ford.com/shop/en/us/gasket-7859317-1#sectionId:4364674 (Not sure on gasket, I have a hybrid and my transmission is different and the diagram is not definitive on exactly where the screen is.)
According to this https://parts.ford.com/shop/en/us/gasket-7859317-1#sectionId:4364674, Mercon-V would be the correct fluid for 2005 CD4E Transmission, Note on the chart:
Due to fluid recommendation changes approved by Ford Motor Company, some older owner guides, workshop manuals and fluid level indicators may not show the same fluid as the above chart. For those application service with the fluid shown in this above chart.
ITBland
Postby tml1138 - December 3rd, 2018, 10:29 am
Hello. Does anyone have the OEM part number for the 4 pin trailer hitch wire harness for a 2005 Mercury Mariner Premier V6 4WD? Thanks!
tml1138
Postby bellj - November 16th, 2020, 12:25 pm
What is the part number for the front drivers door weatherstrip on a 2005 Escape XLT? I found this YL8Z-7820530-BA but I'm not sure if its correct or which side of the escape its for. Thanks for your help
bellj
My nickname: bellj
My vehicle: 2005 Ford Escape XLT
My vehicle's name: The Truck
Postby Charles - April 13th, 2021, 2:45 pm
bellj wrote:What is the part number for the front drivers door weatherstrip on a 2005 Escape XLT? I found this YL8Z-7820530-BA but I'm not sure if its correct or which side of the escape its for. Thanks for your help
Ford Parts.com
Present Vehicle
2015 F450 Platinum Crew Cab Long Bed DRW, White Platinum Tricoat, 6.7L Powerstroke Diesel, 225/70R/19.5 tires, Almost every option known to man (except a sunroof). Ford 27.5K Fifth Wheel Hitch; AirRide LoadLifter 5000 Air Suspension System with LoadController Single Air Compressor System; 60 gallon RDS Aluminum Auxiliary Tank; Lund 6132 5th Wheel Truck Box
"19.5s are chick magnets"
Former Vehicles
Charles
E-C LEVEL 22
My nickname: Charles
Previous
Return to Part Numbers
