2003 Escape Nylon Screws/Rivets for interior Trim
Review and request part numbers here!
Postby austinm655 - April 14th, 2016, 7:00 pm
I am looking for the Nylon Screw rivet things that hold the interior trim in on a 2003 Escape. I broke quite a few of them and cannot seem to find replacement ones. I attached photos of what I am looking for. Any help is appreciated. They do not need to be the same color, just as long as they work the same. Thanks!
austinm655
My vehicle: 2003 Ford Escape XLT 4x4
My vehicle's name: Miranda
Re: 2003 Escape Nylon Screws/Rivets for interior Trim
Postby Mike Dee - April 15th, 2016, 7:40 pm
If you have ever tried to match those up you will know that theres many sizes and they all appear to be similar, I would go to a wrecker and grab a few handfuls from various parts from another escape, theres dozens of them on most cars now, holding mudguards, bumper covers, insulation under hoods, interior trim, etc.
You can also get them from the dealer and some parts stores, sometimes they only have one size though, a generic part that may or may not fit. You will usually pay premium prices for these.
Mike Dee
Congratulations on reaching 500 posts!
Postby AussieChris - April 8th, 2019, 9:04 am
We call those fasteners "scrivets". Since it's not black, your best bet is get replacements from a wrecked Escape of the same trim color and year.
AussieChris
Postby 14theRoad - April 18th, 2019, 2:59 pm
Ford and most OEM's refer to them as Push Pin or Push Pins.
You can try to find them on fordpartsgiant dot com. Enter in the make/model/year of the vehicle then start drilling down by body/interior etc. or just search PIN or Push Pin. You'll need to know the length of screw section and the diameter of the nut shaft just under the flange for the hole size. Both should be measure in mm to have an idea if you're looking at right one.
You can also look at Amazon for universal ones. That color might be hard to find though.
Return to Part Numbers
