2002 2.0 hose below the upper rad hose
Postby YOV-10D - August 7th, 2017, 12:25 pm
On the front side (facing the radiator) of the thermostat housing, two hoses are attached. One is the upper radiator hose; the other, below it, makes a right angle turn and connects to a pipe that disappears below/behind the exhaust manifold.
Does anybody know the part number of this 2nd hose? No luck on eBay, Amazon, Rock Auto, Ford Genuine Parts, or Gates.
I'm guessing that this hose is simple enough that it's meant to be "cut to fit" from a large roll.
Problem is i don't know its diameter and my local Advance Auto Parts doesn't carry "cut what you need" generic lengths of right angle hose.
YOV-10D
My vehicle: 2002 Tribute 2.0 2WD 5-spd
My vehicle's name: Yukari
Re: 2002 2.0 hose below the upper rad hose
Postby bangster - August 7th, 2017, 6:16 pm
On RockAuto did you look in Cooling or Heating and Air Conditioning?
Is it a smaller than 1 inch hose?
Anything like http://www.rockauto.com/en/moreinfo.php ... 65&jsn=453 or http://www.rockauto.com/en/moreinfo.php ... 65&jsn=454
Nav (boo), Power Liftgate
bangster
E-C LEVEL 6
My vehicle's name: magnetic
Postby YOV-10D - August 7th, 2017, 7:39 pm
Thanks for the reply. However it's not those hoses; nothing that complicated. It's literally just a plain old "L" shaped hose, which makes it all the more irritating that no stores or part databases seem to acknowledge its existence. Don't yet know the diameter but will remove it next weekend and measure.
YOV-10D
Return to Part Numbers
cron
