PCM Power Diode: 2010 MMH
Postby buckyswider - March 24th, 2018, 7:20 pm
I/S/O part number for the PCM Power Diode for a 2010 Mercury Mariner Hybrid.
I'm at the point where I'm just throwing parts at it!!! :horse: :horse: :horse:
Thanks!
Mine since 3/18/2017 (with 114K)
Factory Nav, Leather Package, Sunroof
buckyswider
My vehicle: 2010 Mariner Hybrid
Re: PCM Power Diode: 2010 MMH
Postby bangster - March 24th, 2018, 8:17 pm
I have yet to see many different ones of these, I have a collection of them from various Fords. Some are black and some are beige, but they all seem the same. I scavenge fuses, circuit breakers, diodes, etc from the you pull it places for my projects (just some here and there). Sometimes they make it back into a car, usually not.
F5TZ-14A604-A
Do you have a digital voltmeter with a diode test selection? Even the cheap/free Horrible Freight ones have it, you can test it if it beeps one way but not the other. Diode mode will actually put voltage out and not just be in ohm meter setting.
Nav (boo), Power Liftgate
bangster
E-C LEVEL 6
My vehicle's name: magnetic
Postby buckyswider - March 24th, 2018, 9:03 pm
Thanks! Found one and ordered. Once I pull the old one I'll test it. It's an intermittent issue, so I'll try to jiggle and jaggle and everything else to see if this might be the intermittent cause. Like I said, just throwing parts at this point based on causes found of similar symptoms on F*rds. PCM relay, PCM diode, after that will be the PCM itself, maybe the battery junction box, and then onto wire harnesses. Wish they was another way. I tagged on to the end of the "wet PCM" thread over at the problems board if you're really bored!
buckyswider
Return to Part Numbers
