01-04 Escape recall for rust belt states 14S02 RECALL
Official Ford recalls and TSBs!
Postby expressonate - April 4th, 2014, 1:31 am
Hello all, just found out about a new recall posted today (4/3/2014) for 01-04 Escapes.
If your car is originally sold in, or currently registered in a rust belt state, you need to setup an appointment for the ft control arm mounts to be inspected. If yours pass the inspection, it's fine to drive till parts come out sometime in June or so. If it doesn't pass, you will be put into a rental car at no charge to you except for fuel, until parts are available.
Contact your dealership to setup an appointment for the inspection, but the replacement parts are not out yet for the fix. If your vehicle is not safe for the road, you'll be put into a rental asap (the dealership may not have one at the time). The inspection is supposed to take around an hour or two total time, but your dealership may need more time based on scheduling.
I have the dealership letter in front of me, but dont have a way to scan it other then by taking pictures of each of the 6 pages.
Take care, and happy motoring all!
~Nate
expressonate
My nickname: Nate
My vehicle: 2012 Escape XLS, FWD, 5 speed
My vehicle's name: Hunter
Re: 01-04 Escape recall for rust belt states 14S02 RECALL
Postby Mantruck101 - April 4th, 2014, 2:07 am
My parents' 2001 had both front control arms replaced ages ago due to rust. Is that what this recall is for?
Current: 2013 Volvo XC60 T6 AWD - 49K
Sold: 2010 Escape XLT V6 4WD -125K+ miles when I handed over the keys :-(
Mantruck101
E-C LEVEL 7
Congratulations on reaching 1,500 posts!
My vehicle: 2013 Volvo XC60 T6 AWD
My vehicle's name: The Meatball
Postby expressonate - April 4th, 2014, 3:55 am
Not sure, looks like it's where the control arms mount is the issue, not the arms themselves. However, like most recalls, if you paid for the work before it was announced as a recall, they usually reimburse you if you have the recite still. I suggest calling ford customer service and seeing what all gets replaced. It's NOT in the letter that I have. It looks like the front subframe is getting replaced on vehicles that require it, due to corrosion.
~Nate
expressonate
My nickname: Nate
Postby N6CRV - April 4th, 2014, 1:31 pm
Hello, I see it goes up to the 04 but my 05 has a build date of 3/04 wonder if is would be under the fix as so close to 04?
Don
N6CRV
E-C LEVEL 4
My vehicle: 2005 Escape 2.3L XLS
Postby Bgdb22k - April 7th, 2014, 1:27 pm
thanks for the heads up, i will be looking into this for sure! :thumb:
Bgdb22k
My nickname: Nate
My vehicle: 2003 Ford Escape Limited 4x4
My vehicle's name: None yet
Postby RobtRoma - April 7th, 2014, 2:31 pm
Bgdb22k wrote:thanks for the heads up... :thumb:
+1
Thanks for posting this Nate :thumb:
Here is a link posted by Escape94, in a different thread, to an NBC News article on the recall:
**EDIT** The linked article has quite a few issues. Mainly, it states it's for 2001-2004 hybrids. There were no hybrids in those model years. The recall is for certain non-hybrids made those years.
The real art of conversation is not only to say the right thing at the right time,
but also to leave unsaid the wrong thing at the tempting moment...
RobtRoma
Super Moderator and E-C's 100,000th AND 200,000th Poster
My nickname: Rob
My vehicle: 2002 XLT 4x4
My vehicle's name: The Mean Green Machine
Postby feh2goup - April 7th, 2014, 9:46 pm
The article has some serious factual problems. I don't think 386,000 Escape Hybrids were ever built. I think it was around 120,000. Second, the recall is mostly for 2001-2004 Hybrids, but the Hybrid came out in 2005.
2009 Escape Hybrid Limited AWD, Black, bought Jan.2013
- replaced ambient temperature sensor
- replaced two hvac blend door acutators
- updated SYNC software
- replaced water pump
- brake job
- replaced steering column
- replaced TPMS sensor
- multiple rear hatch water leaks fixed
- rattle in dashboard resolved as loose bolt in steering column coupler
- replaced underbody a/c lines to rear hvac
- replaced backup sensor
- replaced sway bar links
- replaced one outer tie rod (105,000 miles)
- replaced right front wheel bearing
- replaced ball joints
- another brake job
- replaced a/c condenser
- replaced tailgate latch
- replaced tailgate support struts
- replaced underbody a/c lines to rear hvac (2nd time, $2000 each time)
- replaced driver door keypad
- replaced another outer tie rod
- replaced a/c compressor
- replaced hatch glass hinges
- replaced hatch wiper arm and attachment hardware
feh2goup
E-C LEVEL 5
Postby FordService - April 7th, 2014, 9:58 pm
Hi everyone,
If you'd like, shoot me a PM with your VIN and I'll check to see if your Escape is affected by this recall.
Todd
FordService
Yes, a real, verified Ford Customer Service Representative
E-C LEVEL 6
Postby Bgdb22k - April 7th, 2014, 10:54 pm
Mine is part of this recall. Thanks Todd!
Bgdb22k
My nickname: Nate
Postby RobtRoma - April 8th, 2014, 3:11 am
feh2goup wrote:The article has some serious factual problems. I don't think 386,000 Escape Hybrids were ever built. I think it was around 120,000. Second, the recall is mostly for 2001-2004 Hybrids, but the Hybrid came out in 2005.
I know you are right on your second point but I'm not sure about the 1st one... Anyway, the recall is not for hybrids according to this Oasis Broadcast:
4802 -Announcing Safety Recall 14S02
‎Thursday, ‎April ‎03, ‎2014, ‏‎8:00:00 PM
Safety Recall 14S02: Certain 2001-2004 Model Year Escape Vehicles Operated in Corrosion States - Front Subframe Crossbrace Installation. Please see FMCDealer.com for more details.
RobtRoma
My nickname: Rob
Next
Return to Recalls and TSBs
cron
