Fuel Delivery Module Flange
Official Ford recalls and TSBs!
Re: Fuel Delivery Module Flange
Postby MadMax - February 12th, 2018, 5:19 pm
Thanks for this, I will print and take it to my dealer
Postby Touringmike - February 13th, 2018, 6:25 pm
Stay tuned, mine is going in Thursday 2/15/18.
2+ years ago when I took it in for the TB SFTWR update, I got it back 2 weeks later with a newly remanufactured engine..... :shrug:
Well, the engine was knocking at 30K miles, so they just replaced the whole thing.
Anyway, time for the new flange.
Last edited by Touringmike on February 15th, 2018, 7:04 pm, edited 1 time in total.
Touringmike
My vehicle: '11 Limited (gone) '19 EdgeST
Postby Touringmike - February 15th, 2018, 7:02 pm
So, I had the work done today.
Good news: appears to be a non-issue, everything works as intended.
Bad news: 2 items surfaced during the check-up.
1. My 19K miles, 32 month old engine has mysteriously sprung an oil leak of
the "significant" type. (Nothing on my garage floor, but this time of year, snow & salt scrum
in the garage make it hard to see)
2. Coolant is "dirty" and needs flushing.
Hmmm. It was replaced at Engine swap-out. Dealer, who replaced the engine, didn't know he
replaced it at the check-up time, but I told him about the replacement, and now it's no longer "dirty". :shrug:
Regardless, made another appt. next Monday, to have them put some dye in the oil, and find the leak.
Now, I do all of my own oil changes/maintenance, so I'll look at the bottom end this weekend,
and decide if I really want to take it back.
Service guy said there should be a 3 year warranty on the motor, but I recall the Service Order
stating only 2 years. I also still have the extended warranty from Ford until Aug. 2018,
so not a big deal I hope.
To this point, I've been satisfied with the remanufactured engine, and the install, but,
I'm kind of leary about going back.
Touringmike
Postby csonni - February 15th, 2018, 7:21 pm
Thanks for update. Puts me a bit more at ease.
csonni
Postby wildcat62 - March 19th, 2018, 7:02 pm
I wanted to update this in case anybody had the same issue. Took it back to the dealership & they said there was air trapped in it. Installed new clamp & so far so good. Hoping that's the end of it.
wildcat62
Postby csonni - May 17th, 2018, 3:44 pm
Just had the work done today. Sure enough, it had to crank about 3-4 times as long to start. Bummer. The mechanic either damaged the barbs on the fuel supply port or didn't use to proper clamp pliers and procedure. I even gave the service manager the printout concerning the issue. If the barbs are damaged, then I would think a new fuel module will have to be installed. I hope this isn't going to be something I have to take up with Ford Canada.
csonni
Postby Touringmike - May 17th, 2018, 3:59 pm
Hmmm, you're not having good luck at all. :worry:
3 months in, mine starts right up, never a long crank.
Touringmike
Postby csonni - May 17th, 2018, 4:00 pm
Touringmike wrote:Hmmm, you're not having good luck at all. :worry:
They've been known to do shoddy work before. When I questioned whether or not they could do it properly, they asked if I wanted to decline the recall. Obviously not. Now I wish I had.
csonni
Postby csonni - May 17th, 2018, 4:09 pm
Found this:
"Subsequent repairs should be claimed as related damage, not service part warranty."
https://ford.oemdtc.com/2464/16s41-fuel ... ry-mariner
csonni
Postby MadMax - May 17th, 2018, 9:46 pm
When I took mine back Ford was really good about correcting the issue and it's been fine since
PreviousNext
Return to Recalls and TSBs
