I recently acquired a 2012 XLT with drivers door keypad entry, but it only came (third owner) with two "regular" keys (I believe PATS?). They are Ford keys, and appear to be the chip kind. No integrated key/remote (IKR) keys nor any standalone remote fobs.
When I called around to get remote keyless added, local aftermarket installers told me they had never seen one without remote keyless, was I looking to add remote start? They indicated it should be just a matter of getting and programming a remote key/fob, yet when I called the local Ford dealer with my VIN, they indicated it would over $1000 to add a complete Ford remote system keyless system. When I found the 2012 order guides here, it indicates keyless remote is standard on XLS, so it should be on my XLT, same as the aftermarket guys said.
So, scratching my head and wondering:
1) How can I verify that my vehicle has the remote receiver? Or is it "unpossible" for it to not have it since it was std equipment.
2) Can I just add "fobs" for remote lock/unlock? That's my preference unless it's a lot heavier lifting than #3.
3) I'm thinking I should be able to add, or have the dealer add, a third key, but an IKR, which is not my preference as I had a 2010 Fusion with them and prefer the key/fob combination (had a Ranger with that combo). From the reading I did here, sounds like this would require two original keys, which I think I have, but can I verify that somehow if I end up having to go this route.
TIA!
