by joemarine1990 - February 18th, 2013, 12:09 am
Sorry to keep y'all waiting for my report on the TopR lift kit I recently purchased. I can't get too detailed right now, just time for a brief message. I promise I will soon post pictures and details. Short story version: I installed the kit last weekend with the help of an SAE mechanic friend. It went fairly smoothly, just two small issues with the install. But we got it done, and I then took it for a proper alignment as my friend doesn't have alignment rack. So Goodyear had no issues getting it all aligned, good as off the factory floor. I have been driving it for the last week onroad, and no complaints. Slightly firmer ride, but not jarring. Braking, turning all working good. Overall a pretty good ride. I found that right after we installed the lift, I had gained nearly 4.5" of lift!? A guy I work with that is knowledgeable on this stuff, as he goes rock crawling with a totally custom vehicle he put together himself, said that it is not unusual for a lift to be higher than expected but settle down a bit after a few weeks of driving. He believes the springs will 'settle' closer to the advertised 3" lift height. I guess that's good if you only want 3", or not good if you were happy with the extra lift. I will report what level it settles at in the next couple weeks. I just purchased some Cooper Discoverer AT3 tires in the 245/75-16 size which are 2" taller than stock tires, adding another 1" to my total lift. I will take pictures of my Escape next to my daughter's unmodified Escape before and after the tire change so you can see the difference the lift kit made before taller tires. One thing to point out is that it lifted the front and rear the same amount, maintaining the stock rake toward the front. I do have the 2" leveling strut extensions that you can buy on Ebay if I want to add to the front some more to level my Escape, but I don't think I'll try that until I have had the lift kit on long enough to decide how I like the handling before making more mods. I will definitely look into having the drive lines lengthened in the front if I go higher. Anyway, gotta go to bed, so I'll sign off. I know some have been waiting for me to post on the lift, and be patient, more is coming soon.
