Interchangeable parts?
Postby AhuraMazda04 - November 19th, 2014, 12:06 am
I have a 2004 Mazda Tribute LX V6. Looking to upgrade the suspension, very hard to find upgraded suspension parts. Looking for front and rear sway bars. Also KYB Struts any good? Anyone know where I could get Polyurethane bushings? I hear that some of these parts could come from other Mazda or Ford Vehicles, any truth to this? Help and suggestions appreciated! Also Steel Braided Brake Hose, any luck with them?
Zoom, Zooom, Zoom!!!
Mazda Tribute 2001-2006= What you get when an SUV is raised by a family of sports cars.
Before:
After:
AhuraMazda04
E-C LEVEL 4
My vehicle: 2004 Mazda Tribute LX FWD
Re: Interchangeable parts?
Postby underthetire - November 19th, 2014, 12:21 am
Not a huge fan of ss brake hoses on daily drivers, too hard or impossible to inspect, and a lot are not DOT approved. Kyb is a good replacement, and a slight upgrade. You want the best, buy Koni, it all depends on what your using the car for. Poly bushings couldn't tell you. Last ones I did on my mustang were noisy after a year. That's why you usually see them in upgraded suspention components that have zerk fittings.
underthetire
E-C LEVEL 8
My vehicle: 2009 xlt sun and sync 2.5
My vehicle's name: Money saver
Postby Escape94 - November 19th, 2014, 8:58 am
Rancho suspension also makes rear shocks. There's a recent thread about that.
Currently:
R.I.P 6/15/2017 :(
Escape94
E-C LEVEL 8
Postby S-caped 1 - November 20th, 2014, 1:48 am
I'm at 127k and just replaced my original OEM struts and shocks with KYB and so far they have performed well. The OEM struts were toast but the rear shocks were still surprisingly stiff with good rebound so with the fronts being blown any replacement was better. KYB's are definitely a bit stiffer though. I'd also recommend replacing your sway bar links with MOOG's if you haven't already done so. The OEM links are woefully pitiful in every conceivable way. A stiffer set of links go a long way to improving handling. So does a strut tower brace.
S-caped 1
E-C LEVEL 4
My vehicle: 2005 Escape SVT Supercharged
My vehicle's name: El Escapè
Postby zibercat - November 20th, 2014, 11:55 am
I am about to replace my shocks and struts. My 08 E has 160K on them, I got the KYBs two weeks ago, hopefully I will have them change tomorrow after work............
2008 Escape V6 4WD XLT
Kenwood DDX719 with Wireless Backup Camera
KYB shocks and struts
zibercat
E-C LEVEL 4
My nickname: Zibercat
My vehicle: 08 Ford Escape XLT 4WD V6
My vehicle's name: Elvis
Postby MazKid - November 21st, 2014, 2:08 am
Have the KYBs on my '06 Tribute with H&R lowering springs. The combo works quite well IMO.
2006 Tribute i AWD manual
2004 RX-8 GT
2003 Protege5 KL-G4 2.5l V6 swap project
1994 Protege 1.8l BP-turbo swap
1994 Miata, supercharged
1990 RX-7 GXL project
1971 Mazda 1200 Truck project
Yeah, I'm a Mazda enthusiast.
MazKid
E-C LEVEL 1
My vehicle: 2006 Tribute i AWD manual
Postby AhuraMazda04 - December 2nd, 2014, 3:24 am
Well I am going for street performance. Ride comfort means nothing because this vehicle was never a quiet, smooth, ride. I want it as firm as I can get and handling means EVERYTHING. I am trying to find an upgraded stabilizer bar for the front and add one to the rear as well. I haven't found much unfortunately. Any good brands for tie rod ends?
Before:
After:
AhuraMazda04
E-C LEVEL 4
Postby Linna - December 2nd, 2014, 12:14 pm
AhuraMazda04 wrote:Well I am going for street performance. Ride comfort means nothing because this vehicle was never a quiet, smooth, ride. I want it as firm as I can get and handling means EVERYTHING
You definitely want KONI then, they can be custom built to a stiff spec. You could top off with the H&R springs for a little bit extra. You'll should end up with a decent ride and have the best handling possible.
Linna
E-C LEVEL 6
Postby AhuraMazda04 - December 9th, 2014, 4:34 am
Thank you for the recommendation, I was leaning towards them. Know any rear sway bar kits that might work?
Before:
After:
AhuraMazda04
E-C LEVEL 4
Postby escapegirl7 - December 12th, 2014, 10:57 pm
Anyone know where I could get a roof rack from the limited edition "no boundaries package" escape?
escapegirl7
Next
Return to Suspension Mods
Users browsing this forum: No registered users and 9 guests
