Rear Springs Removal
Postby RBNetEngr - July 18th, 2015, 5:09 pm
I purchased the H&R spring kit and am ready to replace the springs on my 2003 Tribute. I've searched the Internet and found many posts and videos about replacing the front struts, and several posts and videos about replacing the rear shocks, but I haven't found anything that mentions removing the rear springs.
From looking at it, it looks to be as simple as disconnecting the bottom of the shock, and disconnecting the swaybar link, and then the trailing arm should drop down enough for the spring to be removed.
Is that all it takes to remove each spring, or is it more involved? If anyone who has replaced these springs could comment, I would appreciate it.
-rb
RBNetEngr
Re: Rear Springs Removal
Postby RBNetEngr - July 20th, 2015, 4:36 pm
I found a posting on this forum that answered my question.
https://www.escape-city.com/viewtopic.php?f=8&t=22418
-rb
RBNetEngr
Postby Escape94 - July 21st, 2015, 5:56 pm
Glad you found what you were looking for. Post some pics before and after :pics:
Currently:
R.I.P 6/15/2017 :(
Escape94
E-C LEVEL 8
Postby RBNetEngr - May 4th, 2020, 12:46 am
Escape94 wrote:Glad you found what you were looking for. Post some pics before and after :pics:
I am finally getting around to posting some Before and After pictures with H&R Lowering Springs, KYB shocks and struts, and Plus Zero tires (255/65R16 Firestone Destination LE2).
This is a right side view with the original suspension:
This is the same view, with the H&R Lowering Springs
Left Side View with H&R Springs:
This is how much each corner was lowered by the H&R Springs.
Measured from center of wheel hub vertical to the fender lip.
-rb
2003 Mazda Tribute ES
-rb
RBNetEngr
Postby DarkStone06 - May 18th, 2020, 7:59 am
Wow great! It only took you 5 years. :lol: This place is dead. I think there's only a few people that still post in here.
Lampis Blue 2005 Mazda Tribute 2.3L 5 speed 4wd RARE!
2013 Ford Flex Limited EB with water/meth
1990 Jeep Grand Wagoneer
2006 Escape XLS 2.3L 5 speed 70k miles (sold) :'-(
2003 Escape XLT 3.0L AWD 106k miles (sold)
1989 Jeep Cherokee 4.0L 4wd (traded for Wagoneer)
DarkStone06
My vehicle: 2005 Tribute 2.3L 5 speed 4WD
Postby EscapeFromLA - September 19th, 2020, 11:35 am
People still post her??
EscapeFromLA
Postby RBNetEngr - September 19th, 2020, 1:13 pm
You just did!
RBNetEngr
Postby Saint203 - December 1st, 2020, 11:35 pm
I just helped a friend of mine lower their escape (2011) and they have a bunch of negative camber in the rear. Did you face any issues with camber or is that something only the newer gens have to deal with?
Saint203
Postby RBNetEngr - December 2nd, 2020, 9:41 pm
My Tribute has a slight increase in negative camber after lowering, but it’s nothing excessive.
How excessive is it? Did you have results from an alignment, or is it just a visual change?
The 2011 has essentially the same rear suspension as the earlier version.
RBNetEngr
Postby Saint203 - December 2nd, 2020, 9:50 pm
RBNetEngr wrote:My Tribute has a slight increase in negative camber after lowering, but it’s nothing excessive.
The negative camber is quite excessive. The vehicle has been aligned so it drives straight and all but it has to have something like -1.5 to -2.5 degrees of camber.
I’m looking into whether or not a set of adjustable upper control arms can be used in place of the lower trailing arms. If so, we could shorten the bar and that should stand the wheel up and not throw off the toe.
Saint203
Next
Return to Suspension Mods
Users browsing this forum: No registered users and 19 guests
