Ford Escape and Escape Hybrid Forums | Mercury Mariner and Mariner Hybrid Forums Mazda Tribute and Tribute Hybrid Forums | Ford Maverick Forums | Welcome to Escape City!
Was looking at YouTube this afternoon and came across a video about a possible issue that you might want to check out if you have the original brake hoses.
Watch this and see if it is something you need to address.
Maps of US States And Canadian Provinces Camped In
Federal Ownership Respectfully Declined Present Vehicle 2015 F450 Platinum Crew Cab Long Bed DRW, White Platinum Tricoat, 6.7L Powerstroke Diesel, 225/70R/19.5 tires, Almost every option known to man (except a sunroof). Ford 27.5K Fifth Wheel Hitch; AirRide LoadLifter 5000 Air Suspension System with LoadController Single Air Compressor System; 60 gallon RDS Aluminum Auxiliary Tank; Lund 6132 5th Wheel Truck Box "19.5s are chick magnets" Former Vehicles 2016 Escape Titanium FWD, Shadow Black, Equipment Pkg 301A, Titanium Technology Package with HID Auto Headlamps, BLIS, Active Park Assist, 2.0L EcoBoost, Panoramic Vista Roof, SYNC3 with Navigation, 19" wheels
Mine has new lines front and rear because i replaced my fronts due to cracking and while me and my friend were bleeding the front brakes while it was on the lift a rear line blew out.
Charles wrote:Was looking at YouTube this afternoon and came across a video about a possible issue that you might want to check out if you have the original brake hoses.
This happened on my first Escape. I have the goodridge Stainless steel lines. DOT certified and they made a nice improvement in feel, response and power.
2005 Escape XLT"SVT"Too much to list but here are the biggies:
Engine: 12' Ford Fusion Duratec 2.5 swap, Massive Speed VCT delete, Crower cams STG1 cams, Verniers adjustable cam gears, Custom fender-well cold air intake, 12' Fusion single stage 2.5 intake manifold, Massive Speed cable driven throttle body adapter/spacer, Central-Florida-Motorsport billet 67mm throttle body, Massive Speed balance shaft delete, Motorcraft SP463 heat range cooler copper plug, 180* thermostat, Massive Speed under drive pulleys (crank + waterpump), Massive Speed Poly rear motor mount, Thunder-Perfromance 4-1 Short header(wrapped), 2.5" cat-less Dual Magnaflow exhaust, Custom tuned by TurboTom@Focus-Power using SCT X4 93+Octane. Suspension/Brakes/Wheels: Ceika custom race series coilovers (10K,8K), Whiteline adjutable HD sway-bar end-links w/ poly bushings, Mevotech TTX HD front control arms, Mevoteck tie-rod ends, Energy-suspension poly front sway bar bushings, Alutec front strut tower brace, Good ridge stainless steel brake lines, 'Tow package' Power Stop front calipers w/ EBC USR rotors and Yellowstuff pads, Stop Tech rear drum upgrade, Mevotech adjustable rear control arms (top and bottom), Custom upper shock tower brace, 09-12 Escape rear swaybar retrofit, Enkei Raijin(black) 18x8.5 w/ Continental ContiSportContact 245/50ZR/18, H&R TraK 20mm wheel spacers, major weight reduction.
