Really nice Escape -Provo, Utah
Run into another E/M/T worthy of a shoutout?
Forum rules
Found an Escape, Mariner, or Tribute worth mentioning?
Thread title should list: color, model, location
Additional required information in the post: estimated model year , time and date, the motivation behind seeking that car out.
You never know - they could already be on Escape City!
Re: Really nice Escape -Provo, Utah
Postby FRENCHY - September 2nd, 2014, 11:42 am
I thought I had seen the chrome liftgate molding :? :shades:
FRENCHY
My nickname: Frenchy
Postby tang - September 2nd, 2014, 12:01 pm
FRENCHY wrote:I thought I had seen the chrome liftgate molding :? :shades:
Probably misleading because the Escape is silver.
If it did, it'd be a Limited, and it'd have roof rails.
PM with wheel questions.
past, but still with the family: 09 Escape XLT V6 AWD
present: 15 Taurus SEL AWD
tang
E-C LEVEL 16
My vehicle: 09 ESC XLT 4WD V6
Postby FRENCHY - September 2nd, 2014, 12:50 pm
Ahhh... Fleet model!
FRENCHY
Postby MadMax - September 2nd, 2014, 1:34 pm
tang wrote:It looks like a base 2010 or later Escape with tinted windows as a factory add-on. The Escape emblem doesn't look like it has room for the 'XLT' bit below it. It's definitely a four-cylinder.
matchgame90 wrote:That is either a late build 2011 or a 2012 with the rear glass handle being separate from the wiper.
I'm pretty sure they all were separate unless I'm misunderstanding something.
matchgame90 is right, the '08-'10 the handle is part of the wiper mechanism '11-'12 it's a separate piece
Formerly: 2006 Mazda Tribute
Postby tang - September 2nd, 2014, 1:59 pm
Pulled up Google to confirm, and was surprised.
Wonder why Ford did that.
tang
E-C LEVEL 16
Postby MadMax - September 2nd, 2014, 2:13 pm
tang wrote:Pulled up Google to confirm, and was surprised.
Probably as a fix for the exploding hatch glass issues that were developing
Postby feh2goup - September 2nd, 2014, 11:18 pm
The '10-'12 had the rear hatch release handle in an added bezel in the lower center of the hatch, plus they had the wide-angle mirror inserts.
2009 Escape Hybrid Limited AWD, Black, bought Jan.2013
- replaced ambient temperature sensor
- replaced two hvac blend door acutators
- updated SYNC software
- replaced water pump
- brake job
- replaced steering column
- replaced TPMS sensor
- multiple rear hatch water leaks fixed
- rattle in dashboard resolved as loose bolt in steering column coupler
- replaced underbody a/c lines to rear hvac
- replaced backup sensor
- replaced sway bar links
- replaced one outer tie rod (105,000 miles)
- replaced right front wheel bearing
- replaced ball joints
- another brake job
- replaced a/c condenser
- replaced tailgate latch
- replaced tailgate support struts
- replaced underbody a/c lines to rear hvac (2nd time, $2000 each time)
- replaced driver door keypad
- replaced another outer tie rod
- replaced a/c compressor
- replaced hatch glass hinges
- replaced hatch wiper arm and attachment hardware
feh2goup
E-C LEVEL 5
Postby underthetire - September 2nd, 2014, 11:30 pm
Mine was a fleet vehicle, and we have 100+ of them at work, all xlt's and the only difference I've seen is they all have drl's.
underthetire
E-C LEVEL 8
My vehicle: 2009 xlt sun and sync 2.5
My vehicle's name: Money saver
Previous
Return to Spotted!
