by feh2goup - November 9th, 2016, 8:41 pm
Actually, my Escape has the easiest clock setting function I've ever used in a car. Turn the radio on, push the "clock" button, use the station selector buttons to punch in the time, and leave it for a few seconds before turning off the radio.
As for the time change, it's just a nuisance. Whether or not kids go or come home from school also depends on the latitude, after all. I got fouled up this year for an early meeting because I guessed wrong whether my watch and phone updated automatically. (Both did, I set the alarm only on the phone, but the phone updated despite my attempt to set offline it to prevent an update. Then because it was offline, the other parties were unable to contact me to find out where I was.) At least the Escape had a predictable time display.
2009 Escape Hybrid Limited AWD, Black, bought Jan.2013
- replaced ambient temperature sensor
- replaced two hvac blend door acutators
- updated SYNC software
- replaced water pump
- brake job
- replaced steering column
- replaced TPMS sensor
- multiple rear hatch water leaks fixed
- rattle in dashboard resolved as loose bolt in steering column coupler
- replaced underbody a/c lines to rear hvac
- replaced backup sensor
- replaced sway bar links
- replaced one outer tie rod (105,000 miles)
- replaced right front wheel bearing
- replaced ball joints
- another brake job
- replaced a/c condenser
- replaced tailgate latch
- replaced tailgate support struts
- replaced underbody a/c lines to rear hvac (2nd time, $2000 each time)
- replaced driver door keypad
- replaced another outer tie rod
- replaced a/c compressor
- replaced hatch glass hinges
- replaced hatch wiper arm and attachment hardware
