Help replace rear calipers on a 05 escape??
Postby Pinz2007 - June 17th, 2014, 5:29 pm
I have a 2005 escape and I need some help replacing the right rear caliper because its sticking, Any help??
Pinz2007
Re: Help replace rear calipers on a 05 escape??
Postby Charles - June 17th, 2014, 7:01 pm
Moved your topic to our Problems and Solutions forum to increase visibility.
Present Vehicle
2015 F450 Platinum Crew Cab Long Bed DRW, White Platinum Tricoat, 6.7L Powerstroke Diesel, 225/70R/19.5 tires, Almost every option known to man (except a sunroof). Ford 27.5K Fifth Wheel Hitch; AirRide LoadLifter 5000 Air Suspension System with LoadController Single Air Compressor System; 60 gallon RDS Aluminum Auxiliary Tank; Lund 6132 5th Wheel Truck Box
"19.5s are chick magnets"
Former Vehicles
Charles
E-C LEVEL 22
My nickname: Charles
Postby Manic Mechanic - June 17th, 2014, 7:42 pm
Here is an example of some basic brake service that me be of some help.
https://www.youtube.com/watch?v=mNiENdP6L78
To detach the caliper after it has been unbolted from the caliper bracket as shown in the above video, the brake hose will have to be unscrewed from the caliper and re-threaded into the replacement unit. The hydraulic system will then have to be bled to remove any trapped air.
Manic Mechanic
E-C LEVEL 4
Postby Pinz2007 - June 17th, 2014, 11:33 pm
Thanks!
Pinz2007
Postby Colleen - June 18th, 2014, 6:46 am
Moderator Message:
Removed duplicate topics.
Colleen
Super-Friendly Moderator
My vehicle: 2009 Mariner Hybrid
Users browsing this forum: Google [Bot] and 99 guests
