2005 Ford Escape - Engine bucks only between 1500 - 2000 rpm
Postby Darkseid - February 18th, 2020, 5:29 pm
2005 Ford Escape XLT 3.0L V6 DOHC - starts and idles fine. Good power up to about 1500 rpm and then again above 2000 rpm. Problem does not exist outside of this range. Pressing the gas pedal is when the symptoms show up within that range. If I let go of the gas pedal and it is in that range it will not buck. No engine codes show up.
When it is bucking within that range occasionally the Theft light will come on with a notice of no power slightly but the car will keep going.
I have done the following to try to assess and fix the issue with no changes to the actual problem:
- Replaced Fuel Pump, Fuel Filter, ICV (Idle Control Value) and Gasket, EGR Value, Inner Manifold Gaskets, Spark Plugs, Coil-on-Plug Boots, TPS(Throttle Position Sensor), Air Filter and the PCV Valve
- Cleaned Throttle Body and MAF (Mass Airflow Sensor) with the proper cleaner, tried using different fuel octanes and fuel cleaners as well
Have used both a mechanic code reader/live data tool along with my own BlueDriver code reader but nothing is coming up out of the ordinary.
Another thing I have noticed is when I punch down on the gas pedal to the floor in order to gain quick speed I do feel some slight hesitation spurts where, in my opinion, feels like fuel is having issues getting through but you would think that some sort of code would show up.
I'm stumped at this point and instead of throwing more money towards additional parts and taking it back to the mechanic again (they were unable to find the issue the first time) I though I would try here.
Darkseid
Re: 2005 Ford Escape - Engine bucks only between 1500 - 2000
Postby Charles - February 19th, 2020, 2:14 pm
I took the liberty of moving your topic to our Problems and Solutions forum to increase the likelihood of getting an answer to your issue. :yes:
Present Vehicle
2015 F450 Platinum Crew Cab Long Bed DRW, White Platinum Tricoat, 6.7L Powerstroke Diesel, 225/70R/19.5 tires, Almost every option known to man (except a sunroof). Ford 27.5K Fifth Wheel Hitch; AirRide LoadLifter 5000 Air Suspension System with LoadController Single Air Compressor System; 60 gallon RDS Aluminum Auxiliary Tank; K&W 500 Series Chest Toolbox
"19.5s are chick magnets"
Former Vehicles
2012 Buick Verano Leather Group - Black Onyx - Sunroof, Navigation, Premium Exterior Package, WeatherTech DigitalFit liners (1st & 2nd Row), Wireless Rear View Camera.
Charles
E-C LEVEL 22
My nickname: Charles
Postby bluto - February 19th, 2020, 3:15 pm
It sounds like you have replaced everything ignition, fuel and air related that would be a usual suspect. I have only a few long shot things to check. First you mentioned the theft light coming on. Have you tried using forscan to scan all the other modules for codes? It seems like you might find a code in the instrument cluster (IC) since it does the anti-theft stuff and syncs with the PCM to allow the engine to start.
The only other big thing that I can recommend is to check the PCM for signs of corrosion. And check all of the ground lugs under the hood for corrosion while you are at it. Both of those could cause un-explained issues.
Current: 2008 Escape XLT
Previous: 2002 Tribute ES V6
bluto
E-C LEVEL 3
My vehicle: 2008 Escape XLT
Postby Chevy406 - November 3rd, 2020, 10:36 pm
I am having a very similar issue. Did you ever resolve it ?
Chevy406
My vehicle: 2001 Ford Escape XLS 3.0L
Postby tomw - November 4th, 2020, 1:52 pm
Fuel pressure regulator...
Fuel pressure sending unit...
Fuel pump / sending unit / pickup 'sock' filter...
Fuel pump 'driver module'...
The electronics of the driver module diddle with power to the pump to diddle with fuel pressure... noted (recognized & reported to computer) by the fuel pressure sending unit.
Report incorrect pressure... Fail to enable the pump to deliver based on ...
I would want to measure the fuel pressure continuously... and check delivery volume.
Does it feel as if you can 'pump' or push/release/push the gas pedal and it has no response? As if running out of fuel? Describe?
tomw
E-C LEVEL 10
Location: NW Atlanta GA burbe - toenails of the foothills
My nickname: tom
My vehicle: 07 mariner 2wd v6
My vehicle's name: moby the white whale
Users browsing this forum: No registered users and 123 guests
