Hello all,
I'm working on a recently bought 2012 Escape XLT (w/o nav).
What I'm trying to do: Take out the factory stereo unit, and replace it with a Jensen CAR70V, fitted into a Scosche double-din faceplate, while adding in an Axxess SWC-1 adaptor in order to retain the steering wheel's media control buttons' functions. I don't mind losing the Sync functions, because the Jensen unit I'm installing has Android Auto, and I'll be using that instead.
As you'll see in the picture below, I've taken the whole center console/stereo/ac section apart -- Which means that, unfortunately, now the Escape is refusing to start. I must've disconnected some harness or connector that's crucial to the vehicle starting, as turning the key now just causes the anti-theft icon on the dashboard display to turn on and blink a few times.
So I've got to figure out these problems before I can drive anywhere again (A genius move on my part, I know!)
At any rate, I'd like to know, in reference to the pic below, what the heck parts "A", "B", and "C" are, what their functions are, and (if I'm lucky) wiring diagrams for these mystery harnesses/connectors.
(I do know that the part I've labeled "C" is a cable that ran along the right side of the stock stereo head unit, and plugged into the control panel on the front of the stock head unit. Should I assume this "C" cable is just for the controls on the stock stereo, and I should just ignore it and tape it off/away?)
I'm also VERY curious as to which part is rendering my car un-startable!
https://i.imgur.com/G5BtoQN.png
Any help is appreciated; thank you all in advance.
