Dual usb extension mount
Postby TheBadazz - November 4th, 2020, 10:41 pm
Hey guys I just picked up a 2007 XLT and want to change the radio. Also I want to replace my cigarette lighter with a dual usb extension
Anybody know how to remove the lighter? Thanks in advance
[IMG]https://uploads.tapatalk-cdn.com/20201105/c739cc5b6a1078a879869a1a5abfd48f.jpg[/IMG]
Sent from my SM-G960U using Tapatalk
TheBadazz
Re: Dual usb extension mount
Postby bangster - November 4th, 2020, 11:32 pm
Is this just for charging, or is this for a radio that has a USB connection? If for charging only, I would just find a USB power adapter that you plug into the lighter. That thing you posted still requires a USB power adapter someplace, and couldn't just replace the power point.
It probably just pops out somehow, all the ones in Fords I have replaced either have a screw on sleeve or you have to press in plastic and it releases it and you can pull it out.
Apparently there is a tool to use so you don't have to get behind it to get it out, seems similar to my 2012 Fusion (I have never seen this tool or used it, as I always have done the release from the back):
Same port/lighter:
Nav (boo), Power Liftgate
bangster
E-C LEVEL 6
My vehicle's name: magnetic
Postby TheBadazz - November 4th, 2020, 11:51 pm
Its for the radio. The radio has 2 usb ports. I wanted the assessable in the front and I think that would be a nice spot. And I don't want to make any holes for it
TheBadazz
Return to Audio/Video Mods
Users browsing this forum: No registered users and 17 guests
