Aftermarket Wheels for 2010 Escape
Re: Aftermarket Wheels for 2010 Escape
Postby csonni - April 7th, 2015, 8:40 pm
Wheel Width is 7.50 in and bolt pattern is 5-114.3mm That's all the specs they give.
csonni
Postby ExplorerTom - April 7th, 2015, 9:07 pm
underthetire wrote:All the hub centric rings are now plastic, obviously not designed for a load. I had to use them with my new wheels, no problems yet and have hit a few good pot holes.
Exactly. The load of the vehicle is transmitted through the clamping force generated by the lug nuts torqued to spec.
That's why lug nuts are tapered. And the lug nut seats in the wheel are also tapered. This centers the wheel. This is why it's important to slowly tighten your lug nuts with no weight on the wheel and make the final torque adjustments in a criss-crossing star pattern.
If the steel hub flange were to carry the load through the aluminum hub bore in the wheel, it wouldn't be long before that steel hub flange would beat that round aluminum hub bore into something that wasn't round anymore.
And if that hub flange did the centering, don't you think it would require a much tighter fit than just tossing the wheel up there and holding it in place while you tighten the lug nuts? With that loose fit, even slightly off-center would result in wicked vibrations at highway speed.
ExplorerTom
E-C LEVEL 6
My vehicle: '06 Mariner & '12 Escape
Postby csonni - April 8th, 2015, 7:18 am
Here are some of the specs I found on one site.
Offset- 42mm
Backspacing- 0mm
Bore Diameter- 73.1mm
On another site, the Bore Diameter is listed as 67.1
What exactly is Bore Diameter- the diameter of the center hub?
csonni
Postby csonni - April 8th, 2015, 9:56 am
Looks like I'll also have to consider the TPMS Sensors. Just spoke with the local Ford garage here and they said I'd have to first find out if the wheels have the band or valve sensors. I suppose there's no way of knowing until you remove the tire from the wheel? Valve Sensors run $100 each! Band Sensors are $75 each plus $25 a band. So, either way, it's going to be another $400. Yikes! I can swap the Band Sensors but the Ford guy said he wouldn't recommend swapping the Valve Sensors. He said he runs his winter tires without the sensors and just puts up with the warning light on. I'd rather not do that with my summer (aftermarket) wheels.
csonni
Postby Rook - April 8th, 2015, 11:29 am
Yes, center bore is the escape hub diameter, escape is 67.1 I believe, so equal or greater than that is ok.
Ford is raping you, amazon has a set of four stems sensors for $100 total, if you are eBay savvy, they can be had at $45 for all four. They are likely stem tpms.
I wouldn't go to ford, a local tire shop would be more than ok and youd save a ton on the actual work, my shop charges $10 a tire or free if I buy from him. But I have known him and did business with h for awhile.
POWERED BY: TheCHIVE
2010 Ford Escape Limited V6 4WD:
A.K.A. Doctor Krieger
MODs: New to me, 2010 Ford Escape Limited V6 4WD
Emergency response: My Emergency Light install thread
EDC/BOB thread:Everyday carry (EDC) and Bug Out Bag (BOB) picture thread
Supernatural wrote:Crowley: "She was a horrible mother. Did I tell you the time that she almost traded me for three pigs, three! I was an attractive child, I could juggle. I was worth five pigs, at least."
Rook
E-C LEVEL 7
Congratulations on reaching 1,500 posts!
My nickname: Rook
My vehicle: 2010 Escape LTD V6 4WD
My vehicle's name: Dr. Krieger
Postby csonni - April 8th, 2015, 11:42 am
Are the Sensors you buy vehicle specific or will any do? I see there is a small programmer that one can buy.
csonni
Postby Rook - April 8th, 2015, 11:44 am
csonni wrote:Are the Sensors you buy vehicle specific or will any do? I see there is a small programmer that one can buy.
No specific and yes to the programmer
Rook
E-C LEVEL 7
My nickname: Rook
Postby csonni - April 9th, 2015, 8:33 am
I think my interest has switched from the Momo RPM to the Momo NEXT wheel, as seen below:
http://www.momousa.com/road-wheels/road ... acite.html
I notice that the width of the NEXT is 7.0 compared to 7.5 with the RPM. The tires I will be swapping to these new wheels are my Firestone 225/65R17. I'm assuming these wheels take a variety of sizes, yes? I'm having to order these wheels from a supplier 6 hours away due to our isolated location here in Labrador. I'm a bit worried about offset, etc. but the wheels are specified to fit my 2010 Ford Escape. Also, I'm not sure if I'm going to need to purchase a wheel kit (new lug nuts) or will my original lug nuts fit these new wheels?
csonni
Postby underthetire - April 9th, 2015, 10:26 am
You don't have to buy the programmer, the tire shop will have one. I got 4 OEM sensors new for 45 on eBay. Worked just fine.
underthetire
E-C LEVEL 8
My vehicle: 2009 xlt sun and sync 2.5
My vehicle's name: Money saver
Postby csonni - February 7th, 2018, 5:06 pm
Just took the leap and purchased 4 (Hubcentric) Fast Wheels Switch Titanium along with a set of new lug nuts. Shipping is free and I got them for $152 each. The exact specs is 17" x 7.5", 67.1 bore, 5x114.3 P.C.D.
Here's the link:
https://www.fastwheels.ca/productinfo.a ... lang=en-US
csonni
PreviousNext
Return to Tires And Rims
Users browsing this forum: No registered users and 15 guests
