Bigger Tires on 17” Rims
Postby Manitoba - July 8th, 2020, 9:33 am
Hello all,
I am sure this has been posted somewhere before, but I can only find concrete answers for the 16” rims. I want to buy some larger All-Terrain tires, I am wondering what size tires I can put on a 2010 Ford Escape Limited with the 17” chrome rims without rubbing issues. If someone has pictures that would be awesome.
Also, if there is a popular size of tire that is larger than stock but is not technically the BIGGEST that will fit, I’m interested in that too. It doesn’t have to be the absolute biggest, just bigger than stock. Thanks!
Manitoba
Re: Bigger Tires on 17” Rims
Postby vpasla1 - July 8th, 2020, 9:47 am
Take the width and diameter for the total tire and rim size for the 16 inch rims. Apply it to your size.
As far as I know, the stock 16 and stock 17 inch rims have the same width and offset.
Regardless of rim size, the wheel wells, suspension parts, and brakes are all the same between the 2009-2012 Escapes. Therefore, the total diameter of tire and rim should work out to the same size, regardless of 16 inch or 17 inch rims.
vpasla1
Postby Manitoba - July 8th, 2020, 12:35 pm
Okay so if I am doing the math correctly (please ignore my stupidity), then these are some of the numbers (Adding rim size to tire size for total diameter).
Total width of the stock 17” rims and tires = 22.76”
Total width of the 245/75R16’s that people say are the max on the 16” rims = 23.23”
Total width of 235/65R17 = 23.01”
Total width of 245/75R17 = 24.233”
Based on these calculations, the popular sized 245/75/R17 may not fit. Does this make sense? Although it’s hard to believe that the 245/75R16’s only add .5” over what comes stock on 16” rim escapes, so maybe I did something wrong?
Manitoba
Postby vpasla1 - July 8th, 2020, 3:35 pm
I'm not sure I follow, I believe the rims are both 7 inches wide, and 245 tire width is based on the tire, not the rim exactly. However, even between brands and tires, you'll find some variation in width between 245mm wide tires.
I was referencing diameter, because that will determine how much of the wheel well will fill up. Anything too big and you'll get rubbing on bumps, turns, or even just driving.
Now going too wide, may cause issues with fender rubbing. However I haven't seen any issue with going 20mm wider than stock sizes, especially since 235 width tires are stock on the 16 inch, so effectively going to 245 should make minimal difference on issues related to width.
Use www.tiresize.com/calculator .
It'll help provide you with what you can do. In your case, a 16 inch tire, sized 245/75/16, is 30.5 inches in diameter. This would be 6.6% bigger than the stock 225/65/17 size. Make note that by increasing the diameter, you're speedometer is going to be off.
So we've established that based on your research in other threads, 245/75/16 fits on the escape without issues. That tells us that a tire and rim combination of 30.5 inches can fit on the Escape, providing it's on the stock rim.
Once you go aftermarket, you're changing rim widths, offsets, and backspacing, and thats other things you have to account for.
So using the link provided, let's take a 245 width, and see what brings up closest to 30.5" diameter on a 17 inch rim. Since you're rim is bigger, you need a smaller sidewall to maintain the same diameter. What I come up with is 245/70/17.
Definitely use the calculator posted above, as I find it really helps to visualize changes to rims and tires.
vpasla1
Postby Manitoba - July 11th, 2020, 11:46 am
Awesome, that’s very helpful. The 245/70/17 looks like it will be the perfect size, that calculator is very helpful. I will try those, thanks a lot!
Manitoba
Postby Touringmike - July 12th, 2020, 10:02 am
What I got for a replacement on my departed 2011: 235/65R17s
Mounted!
Got them from Tire rack, which has selections for up-sizing to fit-replace OEM tires/wheels.
You can even view your vehicle model and color with available wheel selections.
Touringmike
My vehicle: '11 Limited (gone) '19 EdgeST
Postby NF-XLT - July 13th, 2020, 1:24 pm
Glad someone else posted about this. I just recently got myself a set of 245/65/R17 to fit the set of SAP wheels I managed to find. I an concerned about fitment.
So far I believe width of the tire is the same as the stock 16's I have. Just concerned about diameter. I've gotten a set of 5mm Hub Centric spacers for the front but think I may need to find a leveling kit for the front. Not sure as I have not put the wheels on yet. Maybe if anyone else has any advice or info about this size of tire.
NF-XLT
Postby vpasla1 - July 13th, 2020, 2:20 pm
NF-XLT wrote:Glad someone else posted about this. I just recently got myself a set of 245/65/R17 to fit the set of SAP wheels I managed to find. I an concerned about fitment.
Use the calculator I posted above. You're 0.5" larger in diameter than stock size. You shouldn't have any issue with the SAP rims.
vpasla1
Postby bangster - July 13th, 2020, 9:38 pm
If the diameter is .5 inches bigger, then they will be .25 inches closer to the wheel wheel or whatever you are worried about. Should be able to easily measure that.
I don't know what the suspension looks like on your Escape, on my Fusion (a completely different vehicle and not at all germane to your question or worry) I can't run the stock Mustang size (235/50/18) on wider wheels with more backspace easily, they are 1.3 inches diameter larger that 225/45/18, so .65 inches closer to the upper control arm and the front and rear wheel wheel when at full lock. A spacer would actually make them hit the fender (not the wheel well) but clear the spindle better (I am going with 3mm spacers and stock tire size on the wider wheel, I already have an older tire mounted to my new wheels to test fit).
Nav (boo), Power Liftgate
bangster
E-C LEVEL 6
My vehicle's name: magnetic
Postby NF-XLT - July 14th, 2020, 7:44 pm
Ok so after having the new tires (245/70/R17) mounted on the SAP wheels I measured them out and they are just under 30.5 inches in diameter and the width of them is around 9.5 inches which was the same as the 16 inch wheels I currently have on. So as far as rubbing issues I don't think I'll have any because they are still on a stock wheel so the offset should still be +40.0mm. I don't think I'll need the spacers for them but I have them anyway just incase the test fit reveals some issues.
I'm going to be putting them on over the weekend as well as some other things so I'll get photos up from the before and after.
NF-XLT
Next
Return to Tires And Rims
Users browsing this forum: No registered users and 12 guests
