Center bore (Taurus Wheels)
Postby Saint203 - July 21st, 2020, 5:48 pm
I’m looking at a set of 2013 Ford Taurus SHO wheels that are dirt cheap and easily repairable (and a good excuse to buy a powder coating machine.) After doing something research I found that the center bore of the wheels are 66.7mm while my 08 Escape has a hub at 67.1. This being said, is there any possibility that the wheels will slide onto my hub or will I have to get them drilled.
Saint203
Re: Center bore (Taurus Wheels)
Postby bangster - July 21st, 2020, 9:47 pm
I think you will find that the Taurus center more is even smaller than they number you out there. I tried a set on my 2012 Fusion (67.1 center bore) and no way they would work. I think they have the same center bore as my 1997 Cougars and Mark VIII at 63.4mm.
A competent machinist can fix that, but I found it difficult to get any wheels or brake rotors machined (converting rotors to 5x108 from 5x114.3) no one wanted to do work... I slotted them myself with a air tool, and the bore didn't matter as long as it was bigger on the wheel than the hub (as they have tapered lugs that are lug centric).
Nav (boo), Power Liftgate
bangster
E-C LEVEL 5
My vehicle's name: magnetic
Return to Tires And Rims
Users browsing this forum: No registered users and 12 guests
cron
