Door Ajar light, again..
Re: Door Ajar light, again..
Postby Midshift - June 16th, 2017, 6:20 am
Possibly different in each state but will the door ajar light fail me in an inspection (even when their is no door open) ??
If so, Im F'd cuz theres no time or money to fix the relentless issue.
I may have to pull the cluster and pull that bulb.
"Mods":
6000k Bi-Xenon HID Headlamps/Fogs (Diode Dynamics LLC - STL Mo)
Complete Vehicle Std--to--LED Bulb swap (SuperBrightLEDs - Maryland Heights Mo)
K&N Air Filter
Body molded mudflaps
Custom MTX/Kenwood Audio system
Weathertech floormats
Midshift
E-C LEVEL 5
My nickname: Midshift
My vehicle: '05 Mariner Luxury 4WD V6
My vehicle's name: Lil-4WD
Postby rotary_powered - June 16th, 2017, 1:35 pm
If you have a bluetooth OBDII code reader, go download Forscan, you can check which door is open,
rotary_powered
My vehicle: 2002 Escape XLT 4x4
Postby thesavo - June 17th, 2017, 12:01 am
rotary_powered wrote:If you have a bluetooth OBDII code reader, go download Forscan, you can check which door is open,
Thoughts exactly. You can call up live data like a door state for each door. I did try this to troubleshoot a 2003 expedition.
All Ford's develop this issue. I had a 2003 Taurus and a 1998 explorer, 2004 towncar, all with the same issue.
Some lube it up with water displacer no. 40. Then open/shut the door ~30 times to free up the ball switch. Aftward it's time for white lithium grease.
Sent from my SM-N910V using Tapatalk
thesavo
E-C LEVEL 6
My vehicle: 2008 Mariner Base
Previous
Return to Mariner Manor
cron
