2006 Mercury Mariner FWD V6
When I attempt to activate the cruise control like for example while driving on the interstate, it will not engage. Please assist.
Sent from my SM-S327VL using Tapatalk
bangster wrote:Oops, I meant the ABS light, the speed control one isn't one that is tested during the bulb test. I think I see at the edge the ABS light on. If it goes out when you start then shouldn't be the fuse.
The speed control defaults to off every time to shut off the car. When you press On the steering controls does the speed control light come on the dash? Does the horn work? It could be the control switches or the clock spring or the module or many things. I have had to replace a clock spring and replace controls both to get cruise working again. It is still mechanical/external control on yours I think, it isn't a drive by wire vehicle where that moved to the PCM.
