2014 Escape lower engine cover p/n?
Talk about anything related to your 2013 - 2016 Escape and 2012 - Present Kuga here!
Postby Wayne J - September 30th, 2018, 7:01 pm
Our 2914 Escape has a cover under the engine that protects it from road debris. It was damaged while driving on a muddy dirt road. How can I find the part number for this?
Thanks,
Wayne
Wayne J
Re: 2014 Escape lower engine cover p/n?
Postby bangster - September 30th, 2018, 7:44 pm
I haven't looked at mine yet (dealer maintenance contract), but I think they are the same for all engines (often they are different if they have a door to access the filter and/or the drain plug).
I think EJ7Z6P013A is what you are looking for. I don't know for sure, and don't know what engine that might work for.
I am pretty sure they have to be removed for an oil change, so they don't have a door so they can fit all models with all engines.
Nav (boo), Power Liftgate
bangster
E-C LEVEL 6
My vehicle's name: magnetic
Postby Wayne J - September 30th, 2018, 10:47 pm
bangster,
I do believe you have the correct part number. Now I have to find the least expensive place to order the part.
Thank you,
Wayne
Wayne J
Postby GPBoss - July 2nd, 2019, 1:39 pm
Thanks for the PN. I verified that it's the correct part I needed so I went ahead and ordered it at a really good deal https://www.fordpartsprime.com/oem/ford-front_shield-ej7z6p013a.html
GPBoss
Return to 2013 - 2016 Escape / 2012 - Present Kuga General Discussion
cron
