"PTU" [transfercase] drain plug.
Talk about anything related to your 2013 - 2016 Escape and 2012 - Present Kuga here!
Postby crosshairs4469 - January 17th, 2019, 5:38 pm
Does your 2008-2012 escape have a "power transfer unit" (transfercase) drain plug... Mine appears to be welded shut.Image
Sent from my VS995 using Tapatalk
crosshairs4469
Re:
Postby bangster - January 18th, 2019, 9:45 am
There is only a side fill plug, so you have to have to suck out the old stuff via that, and fill it until the level is at the bottom of the fill plug. Some PTUs on some vehicles (mainly larger with the ecoboost and 6F55 transmissions) have a drain, some have a cooler.
Re: "PTU" [transfercase] drain plug.
Postby pommesdeux - January 24th, 2019, 8:24 am
My 2011 has just the side fill plug. I have used a suction pump twice and seems like I got most of the old crud out. I replaced with Lucas 75-140 and so far things seem to be OK. Plan on doing it each spring along with a partial trans oil change. FORD REALLY DROPPED THE BALL ON THIS ONE.
Sent from my SM-T377W using Tapatalk
Just waiting for a roadtrip and a excuse to burn some gas!!
pommesdeux
My vehicle: 2011 Tribute GT 4X4
Return to 2013 - 2016 Escape / 2012 - Present Kuga General Discussion
