someone isn't happy sitting...
Postby bangster - March 29th, 2018, 4:40 pm
So for the 4th or 5th time this year, my wifes Escape has messaged me telling me that it doesn't like sitting doing nothing for 2 weeks. Looks like I have to go start it up, wash it, and it will go back into use next week.
The 4,000 miles that it would probably have gotten have all gone on my 2000 Grand Marquis. I did try to go and start it up and move it but it has just been a lawn ornament because other than Android Auto, don't really feel like driving it.
Nav (boo), Power Liftgate
bangster
E-C LEVEL 5
My vehicle's name: magnetic
Re: someone isn't happy sitting...
Postby MadMax - March 30th, 2018, 12:38 am
:lol:
Well, what can you say? Busy little Escapes are happy little Escapes :yes:
Postby 14theRoad - August 16th, 2018, 2:40 pm
Most cars batteries do well when they sit for too long. If it's going to sit for more than week, use a battery tender. You can get an adapter that allows it to be plugged into an active accessory power outlet, if on exits on the 2017.
14theRoad
E-C LEVEL 6
Postby Aggie - September 28th, 2018, 7:40 am
Is the 12v outlet in the trunk area of the car an active outlet?
Aggie
Postby Charles - September 28th, 2018, 10:45 am
Aggie wrote:Is the 12v outlet in the trunk area of the car an active outlet?
It is an active outlet if my memory is correct. Wife and I used it to power a 12 volt cooler for those trips in the summer.
Present Vehicle
2015 F450 Platinum Crew Cab Long Bed DRW, White Platinum Tricoat, 6.7L Powerstroke Diesel, 225/70R/19.5 tires, Almost every option known to man (except a sunroof). Ford 27.5K Fifth Wheel Hitch; AirRide LoadLifter 5000 Air Suspension System with LoadController Single Air Compressor System; 60 gallon RDS Aluminum Auxiliary Tank; K&W 500 Series Chest Toolbox
"19.5s are chick magnets"
Former Vehicles
2012 Buick Verano Leather Group - Black Onyx - Sunroof, Navigation, Premium Exterior Package, WeatherTech DigitalFit liners (1st & 2nd Row), Wireless Rear View Camera.
Charles
E-C LEVEL 22
My nickname: Charles
Postby bangster - September 28th, 2018, 12:21 pm
Seems like all the 12v power points are always powered, yes. The front console, cargo area, and if you do not have the 120v power point at the back of the center console. The 120v power point is switched, only on when vehicle is in run.
bangster
E-C LEVEL 5
Postby Charles - September 28th, 2018, 2:52 pm
Actually, according to page 120 of the 2016 Ford Escape Owner Manual, it says:
When you switch the ignition on, you can use the socket to power 12 volt appliances with a maximum current rating of 15 amps.
When you first turn the engine off, the 12 Volt plugs are powered as long as the Infotainment System is powered.
Present Vehicle
Former Vehicles
Charles
E-C LEVEL 22
Postby bangster - September 28th, 2018, 3:10 pm
Pretty sure the 12v power points are always powered, 120v only when the ignition is not off, and the USB ports are on only when ignition is not off. Some Fords the power points are on for a certain time (Gen2 Fusions for example), but unlike most Asian makes, they are not switched.
I have a solar maintainer I could plug in and try, as it has a light that shows power (from either end, car or from solar).
bangster
E-C LEVEL 5
