TSB 10-25-4 -FRONT EXTERIOR DOOR GLASS WEATHERSTRIP DEFORMED
Official Ford recalls and TSBs!
Postby thesavo - October 21st, 2016, 2:10 pm
TSB 10-25-4
FRONT EXTERIOR DOOR GLASS WEATHERSTRIP DEFORMED OR LIFTING - BUILT ON OR BEFORE 5/7/2010
FORD:
2008-2010 Escape
MERCURY:
2008-2010 Mariner
ISSUE
Some 2008-2010 Escape and Mariner vehicles built on or before 5/7/2010 may exhibit the front exterior door glass weatherstrip deformed and/or lifting up from the door flange. This may be due to a lack of retention between the door glass weatherstrip and flange.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
1. Remove affected front exterior door glass weatherstrip. Reference Workshop Manual (WSM), Section 501-11 Glass, Frames, and Mechanisms - Exploded View.
2. Apply a strip of 3M‘Safety-Walk‘ Slip-Resistant General Purpose Tapes, or similar (obtained locally) to the outer flange surface at the center of the door. Cut grip tape to approximately 2.5" X .5" (64 mm X 13 mm).
(Figure 1)
Figure 1 - Article 10-25-4
3. Install new revised exterior door glass weatherstrip. Reference WSM, Section 501-11 Glass, Frames, and Mechanisms - Exploded View.
PART NUMBER ----PART NAME
BL8Z-7821452-BA Moulding - Right Front
BL8Z-7821453-BA Moulding - Left Front
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited
Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB.
Warranty coverage limits are determined by the identified causal part.
OPERATION
102504A
DESCRIPTION
2008-2010 Escape, Mariner: Replace One Exterior Door Glass. Weather Strip Includes
Time To Install Grip Tape. (Do Not Use With Any Other Labor Operations)
TIME
0.2 Hr.
OPERATION
102504B
DESCRIPTION
2008-2010 Escape, Mariner: Replace Both Exterior Door Glass Weather Strips Includes Time To Install Grip Tape (Do Not Use With Any Other Labor Operations)
TIME
0.3 Hr.
DEALER CODING
BASIC PART NO.
7821453
CONDITION CODE
07
Return to Recalls and TSBs
