What did you do to your Escape today?
Talk about anything related to your Escape, Mariner, Tribute, Maverick!
Re: What did you do to your Escape today?
Postby thesavo - July 4th, 2019, 8:02 pm
Installed a heated mirror harness in the passenger door. Now I can get heated mirror glasses for the passenger. It's nice to have on the driver side. Can't wait to have it on both.
Sent from my SM-N950U using Tapatalk
Postby Meatloafmountain - July 4th, 2019, 8:03 pm
Pics of install?
* Blackhorse Grilleguard - Blackhorse Taillight Guards - Plasti-Dipped stock wheels - Plasti-Dipped grille - Spyder Headlights - Dawn Bodyside Molding - LED light bar - Ford Spoiler - Debadged - LED foglights - Tribute taillights - WeatherTech Lampguard Covers - Plasti-Dipped gas door - front air dam removed - TrailFX Rear Bumper Guard - No Boundaries Roof Rack
* WeatherTech Floor and Cargo mats - Saddleman Seat Covers - various Plasti-Dipped interior pieces - Greyman Tactical MOLLE boards
* Magnaflow exhaust - AEM Brute Force filter
* front strut tower bar - Moog Front Sway Bars - KYB Struts - H&R 1 inch Lift Springs, Front & Back - KONI Rear Shocks
* Optima Yellow Top battery
UpComing Mods / Repairs / Projects:
The Retrofit Source 2nd Gen Fog Light Thread | FTS 4X4 Adjustable Rear Lower Control Arm
Consolidated War Wagon Build Thread
Off Roading Thread
YouTube Offroading Channel
Meatloafmountain
My vehicle: 2012 Ford Escape XLT V6 AWD
My vehicle's name: War Wagon
Postby thesavo - July 4th, 2019, 8:38 pm
Sadly no, other than the 50 I took of the connector to re pin it correctly.
Postby thesavo - July 6th, 2019, 3:13 pm
Today I learned you only need a $4 spring loaded punch from harbor freight to remove the sheer bolt for the ignition lock module.
No need for a rotary tool. I'll try a 9L84 switch from the junk yard before I get a new ignition lock module for $150
Postby MadMax - July 7th, 2019, 6:20 am
I've been performing lots of little maintenance jobs that get put off during the winter. I recently had new struts/shocks/springs installed and my E now rides like a new car :yes: so, I'm going over the car and repairing/replacing/touching-up everything that needs it. It's a job I enjoy anyway, but now that my E feels new again I'm especially motivated
It's strange, I'm really hot to get a newer E, but I've never had a car for so long (8 years) that still gives me such good service that I can't part with it. It's a good problem to have :)
Postby SNJEscape - September 13th, 2019, 1:48 pm
Since our 08 Escape is a spare vehicle my wife or I will drive it once a week to keep it running in case I need to do a repair on our 99 Explorer Sport, or my 00 Ranger 4x4 that will tie them up for more then a weekend or if a problem arises during the week. Well last week I took the Escape to work for its weekly drive, on the way home the ABS & the traction control lights came on, after some searching on line the conclusion is a broken ABS tone ring. So today I am off from work so I jacked up the r/s front to check & sure enough the tone ring on the r/s front axle is broken & just spinning on the axle. I replaced the the ring on the l/s axle 5 years ago, so now it is time to do the r/s axle tone ring.
http://www.fordrangerforum.com/members/ ... 1567-a.jpg
2000 Ranger XLT 4X4 Extd Cab 4.0L (My DD)Mods; bug shield, vent visors, bed rails, throttle cable, Mustang dome light, Expl OHC, Expl lighted visors, Expl radio trim panel, Ranger logo floor mats, 4.0 Emblems, 06 Mirrors, 01 F/E swap, lights behind the grille, step bars, color matched bumpers, Lund cab visor, tailgate light bar, yellow fog light bulbs, & powerdome hood.
2008 Escape XLT 4X4 2.3L Mods; Remote start, bug shield, vent visors, Explorer cargo area protector, Husky stickers, & yellow fog light bulbs.
1969 Mustang Coupe (Project & future toy)
2002 Honda shadow VT750 (Wifes toy)
1999 Explorer Sport 4X4, 4.0 SOHC, (Wife's DD) Vent visors, Bug Shield, & Grille Guard.
SNJEscape
My nickname: Mike
My vehicle: 2008 Escape 4X4 XLT
Postby SNJEscape - September 14th, 2019, 10:04 pm
Update: Today I completed the replacement of the ABS tone ring on the r/s front axle shaft. I took it for a ride, & as soon as I got it over 10 mph the ABS light went out & I drove it for about 20 minutes & all seems fine.
SNJEscape
My nickname: Mike
Postby thesavo - October 5th, 2019, 9:01 pm
Today I did the following:
- Drain and fill 3 1/2 quarts of Mercon V in the CD4E transmission
- Rotated the tires. I will probably need new front Snow tire and an alignment. This pair is wearing unevenly and are starting to crack. I will be lucky if they pass inspections
- Clean the windows.
Tomorrow i will be doing the following
- PTU/4x4 fluid change. I already have a quart of Synthetic 75w-140 Gear oil for this.
- Rear Differential change. I got 2 quarts of regular 80w-90 gear oil for this, and clear silicone RTV to make a new gasket.
- Run reduant wires for steering wheel audio control. Time permitting.
Postby bangster - October 5th, 2019, 9:48 pm
I am doing the PTU and rear end in my...Fusion (sorry, Escape is FWD) as it is blowing big globs of gear oil out the vent at the top.
I was surprised how hard it is to find non Royal Purple Synthetic 80w90 (actually no one sells it in quart jugs), semi synthetic, conventional, or 75w90 synthetic.
Postby thesavo - October 5th, 2019, 10:12 pm
bangster wrote:I am doing the PTU and rear end in my...Fusion (sorry, Escape is FWD) as it is blowing big globs of gear oil out the vent at the top.
I didn't care if I got synthetic 80w-90 for the rear diff since most auto parts stores only sold conventional. Although, since you have to make a gasket with Clear RTV, synthetic would last longer. Advance auto sold Synthetic 75w-140 which is what is called for in the PTU.
PreviousNext
Return to Tailgate Chat
Users browsing this forum: No registered users and 15 guests
